Set program zero using XY positioning laser
  • scsmith1451
  • scsmith1451's Avatar Topic Author
  • Premium Member
  • Premium Member
04 Aug 2025 09:54 #332805 by scsmith1451
Replied by scsmith1451 on topic Set program zero using XY positioning laser
A question associated with this project to integrate a crosshair laser into my machine.
At present the crosshair laser has been successfully integrated into the gvcp panel. My next effort is to allow the user to select the coordinate system to set to zero given the position marked by the crosshairs on the stock. I've added a HAL_Combo box which I can select the coordinate system, however, while monitoring the s32 pin with show_configuration I do not see any change in the value of the pin when selecting a different value. I would like to reference both the label and value columns of the liststore associate with the selection. Is that possible without resorting to a handler?
  • scsmith1451
  • Premium Member
  • Premium Member
12 Aug 2025 16:18 #333286 by scsmith1451
I've got most of the gladevcp buttons working on my machine; i.e. I can toggle may laser marker, I can move the table so that the quill moves to the desired X/Y coordinates, and I can set the program zero for the current coordinate system.
However, I'm experiencing a SNAFU. When the laser is on, the machine will not jog. Further, I have to turn the laser off then click some other widget before the machine will jog again.  What might be the cause and the solution?  My implementation requires that I can jog my table until the crosshairs are at the desired X/Y program zero.
These are the HAL commands to toggle the laser:
# *** Crosshair laser Toggle and LED ***
net machine-is-on => gladevcp.crosshair-ctl-active
net crosshair-toggle-out <= gladevcp.crosshair-toggle
net crosshair-toggle-out => gladevcp.crosshair-led
The LED is set to flash when the laser is active as a prompt to turn the laser off after use.
Kind regards;
13 Aug 2025 03:19 #333308 by rodw
Have a look at how Qtplasmac does it. Normally, you would home the machine, turn the laser on and jog the machine. When the laser is in position, press a GUI button  that sets the G54 offsets based on the XY difference between the tool and the laser. Then optionally, goto 0,0 to centre the tool over the laser position. You need to save those offsets somewhere, but best to do in the ini file.
eg:
[LASER]
laser-x 20
laser-y 30
  • scsmith1451
  • Premium Member
  • Premium Member
15 Aug 2025 20:47 #333481 by scsmith1451
Thanks rodw,
I've added the following to my .ini file:
[LASER]
laser-offset-x = -3.2017
laser-offset-y = -0.2124
I've tried several ways that I could think of to reference these values in the gvcp-panel.ui, as CALL parameters to the EMC_Action_MDI widget without success.  I've also tried to just reference them in the auto-xy-zero.ngc file called by the EMC_Action_MDI widget without success.
A review of the online documentation has not been helpful either.
What is the correct method to pass them to the ngc file for execution?
Kind regards,
16 Aug 2025 01:42 #333493 by rodw
Sometimes you need to know where to looks in the docs. how to set a pin value from the ini file
linuxcnc.org/docs/html/config/ini-config.html#sub:ini:custom
  • scsmith1451
  • Premium Member
  • Premium Member
18 Aug 2025 15:18 #333629 by scsmith1451
Still no go.
Here are my ini variables:
[LASER]
Here is my oword macro:
o<auto-xy-zero> sub
;   ( Move table to program start)
    G91 G0 X#<_ini[LASER]laser-offset-x> Y#<_ini[LASER]laser-offset-y>
    G10 L20 P0 X0 Y0 A0        ( Set X/Y/A DROs to zero )
o<auto-xy-zero> endsub
m2
This is the EMC_Action_MDI class in the gvcp-panel.ui
  <object class="EMC_Action_MDI" id="auto-xy-zero">
    <property name="command">o&lt;auto-xy-zero&gt; call </property>
  </object>
and the related button configuration in the same file:
                  <object class="HAL_Button" id="auto-set-xy-zero">
                    <property name="label" translatable="yes">Auto X/Y Zero</property>
                    <property name="related-action">auto-xy-zero</property>
                    <property name="visible">True</property>
                    <property name="can-focus">True</property>
                    <property name="receives-default">True</property>
                  </object>
When the button is clicked, I get the following error message:
[img]data:image/png;base64,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[/img]
A close inspection of the error has [laser] rather that [LASER] which would account for the message if usage is case sensitive.
Otherwise, I have no idea why the ERROR message is being generated.
Also, before I tried to combine both the offset moves and zeroing the DRO, your guidance to home the machine, turn on the laser and then jog to the desired location worked like a charm. However, since I've tried to implement the oword macro, the machine is back to not allowing jogging with the laser on. No idea what may have caused that!
Any guidance would be greatly appreciated.
Regards,
  • scsmith1451
  • Premium Member
  • Premium Member
18 Aug 2025 15:46 #333630 by scsmith1451
Sorry about the gibberish. The image I pasted looked ok before clicking <SUBMIT>. It reads:
"Named paramter #<_ini[laser]laser-offset-x> not defined"
Regards.
  • scsmith1451
  • Premium Member
  • Premium Member
21 Aug 2025 16:02 #333764 by scsmith1451
After several attempt to use the _ini() variables in my macro to move the table to the x/y offset location, I've finally just hard coded the values into the macro.  While this is not the ideal implementation, it does keep the values in a single location should I need to modify them in the future.
At this point I now have all of my gvcp buttons working except the combo box to select the current coordinate system to use for a given job.  I'll work on that option at a later date.  The key frustration is the inability to jog once the laser is toggled.
This is particularly interesting in that both the spindle enable and the spindle coolant are enabled via relays as well and neither of them inhibit jogging after they are activated.
Does anyone have any suggestions regarding why the laser might inhibit jogging?
These are the HAL commands associated with the laser:
net crosshair-toggle-out => hm2_5i25.0.7i76.0.0.output-02
I don't see anything that might be interfering with jogging.
Spindle-enable and coolant-flood, (I'm using M8 to cool my spindle), are configured as follows:
# --- SPINDLE-ENABLE ---
net spindle-enable  =>     hm2_5i25.0.7i76.0.0.output-00
# --- COOLANT-FLOOD ---
net coolant-flood  =>     hm2_5i25.0.7i76.0.0.output-01
The main difference that I notice is that these function are activated by LCNC signals. Maybe there is something associate with these two signals that needs to be added to the laser activation process.
I'm open to any suggestions that might point me in the right direction to resolve this issue.
Kind regard,
23 Aug 2025 04:28 #333787 by pippin88
Replied by pippin88 on topic Set program zero using XY positioning laser
Please post your full config files
  • scsmith1451
  • Premium Member
  • Premium Member
23 Aug 2025 15:55 #333810 by scsmith1451
Thanks for the help pippin88. All config files are attached.
Time to create page: 0.178 seconds
