PUMA 200 Robotarm and some Hal/INI issues
3 months 1 day ago #348321 by hitchhiker
Which infos you need?
I can upload actual hal and ini again.
I thinking about the issue with the moving b axis when turn a axis.
Issue is that the b axis encoder is not reading the moving because it comes from the mechanical buuld of a ans b axis. Should i make a video???
2 months 4 weeks ago #348392 by hitchhiker
today.... get some stuff working...
i managed to eliminate the coupling of axis a to b axis a to c and axis b to c.
then i get it work to home on my edding marks with index signals from the encoders.
i think i am near to a working world mode?! but Z axis doesnt look ok... i upload some videos....
joint mode for handling stuff works perfect... but my world mode.. doesnt work correct... possible someone know the issue of my z axis? i double check all length and offsets for the DH parameters.... the angles are still the same (alpha).
right hand rule.. thumb as Z up.. i must doo the stuff i think... i will make some stuff from cradboard.. after this weekend..headache..
here some youtube shorts
www.youtube.com/shorts/QVSaIWWKXsQ
www.youtube.com/shorts/nbMT6QoQUbg
www.youtube.com/shorts/eSobhr9gZZ0
www.youtube.com/shorts/EBi62z3gkNc
possible i am on the wrong way with my DH parameters and rotations of each axis.. thats why i make a tool from cardboard to identify the issue
thanks
The following user(s) said Thank You: NWE
2 months 4 weeks ago #348405 by Aciera
It's going to very difficult to troubleshoot the basic setup by running random gcode files. You need to take a step back and simplify things so you can actually wrap your head around what is going on.
First you need to verify that your home position is really putting the arm in the pose it should be. Which means the pose shown on the drawing you posted earlier. If your flange is not correctly oriented to the base plane (ie parallel or perpendicular to your table) then you need to adjust your HOME, HOME_OFFSET values in the INI.
Once you have verified that the home position is actually correct, you can check your DH parameters by positioning the arm in different simple poses in joint mode, then switch to world mode and check if the cartesian coordinates in the DRO make sense. Simple poses would be those with joint angles like 0°,90°,180°. Make a diagram on paper, calculate the theoretical XYZ position using your robots link lengths and compare that to the XYZ values in the DRO.
Small inaccuracies are to be expected but if you have a rotation direction or a link direction wrong then your values would be way off.
2 months 4 weeks ago #348413 by hitchhiker
You mean this position?
I was thinking it was only to show dimension?!
2 months 4 weeks ago #348416 by Aciera
Yes, although I think that your DH parameters have the wrist pointing straight down. Having it point straight down instead of 90° to the right as in the image is not wrong but it is a singular pose and hence you need [JOINT_4] 'HOME = 0.1' in your ini file to avoid an inverse kinematic failure right after homing.
In any case, the important thing is that the home pose MUST be the same pose as what you used to derive your DH parameter values. If an angle in the model is 1.570796 then the angle between the corresponding links of your physical arm needs to be as exactly 90° as possible when all joints are at 0°.
In other words:
With all joints at 0° your upper arm needs to be horizontal and your lower arm needs to be vertical like in the drawing. If you have setup your DH parameters for the pose with the hand pointing straight down then the center of the flange needs to be exactly vertical below the wirst.
That is really why you need to understand what those DH-parameters mean in your particular robot.
The following user(s) said Thank You: tommylight, hitchhiker, NWE
2 months 4 weeks ago #348419 by hitchhiker
i got some datasheets... interesting part:
i the joint angle view.... the arm is upside down?!
the arrows and signs show the alpha for each joint?! or i am wrong.. then is my DH parameter list complete wrong...
in the drawing with the measurements... the arm is in the NEST position... dont care.. but all measurements are present... now.. i wonder because:
joint 1 is the base which rotate left and right              alpha 0
joint 2 is the upper arm on the shoulder                     alpha+
joint 3 is the lower arm on the elbow                          alpha+
joint 4 wrist rotate                                                        alpha 0
joint 5 wrist roll                                                            alpha +
joint 6 toolplate rotate                                                 alpha 0
we have a side offset from shoulder rotation point to base rotation point..
we have a side offset from upper arm to lower arm...
but i was thinking that the side offset ist from base turn point to middle upper arm..... complete wrong?!
thanks guys!
