DIY Robot Kinematic parameters,
2 months 2 weeks ago #348783 by Aciera
Replied by Aciera on topic DIY Robot Kinematic parameters,
Is the DH parameters below right?
Those won't work. First indication is the simple fact that you are mixing distances and angles. Also note that genserkins uses 'modified DH' parameters not the standard 'DH' parameters.
I already posted the parameters for your robot that should work for your robot, why don't you start by trying those?
2 months 2 weeks ago #348784 by emresensoy
Replied by emresensoy on topic DIY Robot Kinematic parameters,
First of all, thank you very much for your interest and support. The diagram you sent already formed my starting point. However, since there is a 90-degree difference between the slider joint and the next joint, I wanted to redo the calculations.
Also, since Genserkins only supports rotary axes, I will not be using it. I will recreate the kinematics according to my system.
2 months 2 weeks ago - 2 months 2 weeks ago #348827 by emresensoy
I made a simulation html with claude
Last edit: 2 months 2 weeks ago by emresensoy.
The following user(s) said Thank You: NWE
Time to create page: 3.014 seconds
