deckel fp4ma retrofit
9 years 10 months ago #84194
by bahrabadi
Replied by bahrabadi on topic deckel fp4ma retrofit
all i want is to send lots of gcodes to machine.so if this controller does that,immore than happy to use it.by the way there is just on of those haidenhine boxes in control box .what is with those battries.what are they used for.they are probebly empty right?is there a manual for this controller electrical wiring?these three ports are in picture are encoders becuase when i disconnect them .the axis in monitor doesnt change value.how about that?
9 years 10 months ago - 9 years 10 months ago #84195
by bahrabadi
How about encoders?as i understand they are linear encoder and tachometer.are they useable with 7i77?about those wires; i think i can't do that because i never done that so i dont want to cause more trouble unless i'm certain about what i'm doing
Last edit: 9 years 10 months ago by bahrabadi.
9 years 10 months ago #84197
by ROG
I can't wait till he gets to the PLC logic to control a 17 speed gearbox then
Replied by ROG on topic deckel fp4ma retrofit
tommylight wrote: i would advise on changing the controler, even if everything works out, you will be grateful when you actualy start using the machine.
9 years 10 months ago #84199
by bahrabadi
17???are you kidding me! am i able to use a vfd ?
9 years 10 months ago #84200
Using a VFD is an option but it will not have the full range of power.
Replied by tommylight on topic deckel fp4ma retrofit
I do not recal that mentioned here! That is .........complicated !ROG wrote: I can't wait till he gets to the PLC logic to control a 17 speed gearbox then
9 years 10 months ago #84201
I wrote a HAL component for that:
forum.linuxcnc.org/38-general-linuxcnc-q...ntrol?start=10#81876
But that is a puzzle for the future.
Replied by andypugh on topic deckel fp4ma retrofit
Time to create page: 0.072 seconds
