Retrofitting a 1986 Maho 400E
06 May 2019 14:16 #132965 by PCW
Replied by PCW on topic Retrofitting a 1986 Maho MH400E
Note that the 7I74 is a passive device, so "7i74" will not show up anywhere,
but all the connected daughter cards should show up if the second sserial port is enabled.
  • RotarySMP
  • RotarySMP's Avatar Topic Author
  • Platinum Member
  • Platinum Member
06 May 2019 14:26 #132966 by RotarySMP
The 7i74 won't have pins available will it. You probably need to connect the 7i784 to it then, and see if 7i84 i/o pins become available.
06 May 2019 15:46 #132975 by Glemigobles
Replied by Glemigobles on topic Retrofitting a 1986 Maho MH400E
So I discovered a 2012 forum topic on the subject of configurations and this led me to Big John T's 7i77 tutorial configuration and his sample configurations. Despite being the most obvious option for a newb, PNCConf is probably not the way to go at all. The plot thickens...
06 May 2019 18:31 - 06 May 2019 18:36 #132987 by Glemigobles
Yes, I was looking for 7i84 pins, I'd read about the 7i74 being passive before. I unplugged the other cards and left the 7i77 to try the sample configs I found, but LinuxCNC wouldn't start with them. So instead I got into PNCConf again, selected a 7i77x2 firmware per the 5i25 manual and finally it allowed me to go through all the options. Now I'm going to set up what I can and then modify the config files to enable the 7i74 and the relay FPGA and pendant modules. Then I'll start wiring up components.
EDIT: sorry for the flurry of posts, but after unplugging the Philips I'm on a one-way street to get this going ASAP (there's a bunch of work waiting). I had a programmer buddy over the weekend to help but now that he's back at work I'm feeling lonesome in my workshop and want to exchange ideas all the time :)
Last edit: 06 May 2019 18:36 by Glemigobles.
06 May 2019 18:52 #132988 by Glemigobles
Okay, I can't get LCNC to start with either John's sample config or the config I just made in PNCConf. I'm attaching a file with the log that came up when I tried to open my config. (The text formatting is broken because I copied the file to a Windows machine; it looks good in Linux). Does anyone know what the problem is?
06 May 2019 19:02 #132989 by andypugh
Replied by andypugh on topic Retrofitting a 1986 Maho MH400E
[ 7535.030506] hm2/hm2_5i25.0: config.num_encoders=12, but only 6 are available, not loading driver
It looks like the chosen 5i20 firmware only includes 6 encoders.
The following user(s) said Thank You: Glemigobles
  • RotarySMP
  • Platinum Member
  • Platinum Member
06 May 2019 19:30 #132991 by RotarySMP
You'll get there. This is the first block of my HAL:
You probably want to comment out Matrix_KB, estop_latch MH400E_gearbox for starters.
# HAL COMPONENTS
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
# Driver for MESA 5i25/7i77/7i84 interface cards
loadrt hostmot2
loadrt hm2_pci config=" num_encoders=3 num_pwmgens=0 num_stepgens=0 sserial_port_0=300xxx"
setp hm2_5i25.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z
loadrt mux16 names=jogincr,foincr,mvoincr
#5x5 matrix in scan generation mode to interface the user display panel buttons
loadrt matrix_kb config=5x5s names=maho_panel
#Gearbox Control
loadrt mh400e_gearbox
#external E-stop
loadrt estop_latch
addf hm2_5i25.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf jogincr servo-thread
addf foincr servo-thread
addf mvoincr servo-thread
addf hm2_5i25.0.write servo-thread
addf maho_panel servo-thread
addf mh400e-gearbox servo-thread
addf estop-latch.0 servo-thread
See the line "encoders =3", that is what Andy was referring to.
  • RotarySMP
  • Platinum Member
  • Platinum Member
06 May 2019 19:31 #132992 by RotarySMP
I just tested the drag engraver. It works really well in aluminium.
Mark
06 May 2019 20:00 #132995 by Glemigobles
Okay, so I can edit the number to 6 and see if it works. Thanks a lot guys!
11 May 2019 07:56 #133434 by HaMi
Replied by HaMi on topic Retrofitting a 1986 Maho MH400E
Hello Christian
I am an german User and i need a Dokumentation for the Trk6. Van you sendet me this
Tank you very mich
Harald
Moderators: piasdom
Time to create page: 0.177 seconds
