Retrofitting a 1986 Maho MH400E
7 years 5 months ago #133914 by PCW
Replied by PCW on topic Retrofitting a 1986 Maho MH400E
No, the mode should make no difference
Is this with a blinking green light on the 7I84 (and no red light)?
7 years 5 months ago #133915 by Glemigobles
I guess tomorrow I'm going to rewire the IO pins from the 7i84 to the 7i77 and create a wiring file. Since I have a 7i73 I won't need the pins for the panel that Mark used if I decide to connect the Philips keyboard and pendant. It's better to get to servo tuning and actual milling, even at 100€ this board isn't worth troubleshooting for 2 days in my situation. Though I'm bummed about this, it retailed for 100€ or thereabouts. Were I in a hobby situation you can bet I'd diagnose the everloving beejeezus out of this card.
7 years 5 months ago #133916 by Glemigobles
PCW, yes, there's a blinking green light when LCNC is fired up. That's partly what makes it confusing to me.
7 years 5 months ago - 7 years 5 months ago #133918 by PCW
The question I was asking is if there is a blinking green light when you did the output test,
since you need constant communications for the test to work.
(this is why your halcmd loadrtx xx example would not work without adding
a bunch more commands that set up threads etc)
Last edit: 7 years 5 months ago by PCW.
7 years 5 months ago #133921 by Glemigobles
Yes, I repeated the test with LCNC on and all the cards communicating with each other. It made no difference unfortunately.
7 years 5 months ago #133929 by PCW
OK sounds like the 7i84 is truly bad/broken. We can issue a RMA to repair/replace the card but inexpensive shipping will take a while
The following user(s) said Thank You: Glemigobles
Time to create page: 0.405 seconds
