Retrofitting a 1986 Maho MH400E
Mike_Eitel wrote: Hi RotarySMP
I own a tapmatic. You can exchange the shank. That way it will not get even longer than it is already.
He was talking about pulling the B18 (Jacobs taper) out, so I think that was the plan.
Talking about Jacobs Tapers, the hugest one (JT5) isn't much use for anything, but the shanks with it can be cheaper than dedicated soft-arbors.
- Mike_Eitel
- Thank you received: 183
Nice tool and the action is as he guesses. On top you adjust the max force, according to the thread diameter.
Mike
- Glemigobles
- RotarySMP
- Thank you received: 595
I have only once short step of 8mm height to remove on the layer where the last 2 flute end mill broke, and then a half layer of 6mm depth. The only end mill I have which can reach is a brand new HSS 4 flute 16mm. I used the Clarkson to grind the shank diameter above the flutes, so that the shank won't rub on the walls.
Ill be using flood coolant, plus air blast to clear the chips. Should I just double the feed rate from 120 to 240mm/min for the switch from 2 flute to 4, retaining the same 1500 rpm, or would that be too aggressive?
Mike thanks for the input to the Tapmatic. Nice to see all that all info is on line for these. I will be replacing the MT#3 shank with a 40 taper shank. I'll either make/buy taper removal wedges or visit a friend who probably has them. I tried the Tapmatic suggestion of wacking the tang on the side with a hammer, but it is in too tight for that.
Mark
- Glemigobles
following error 1 - set P to get this value at the requested acc.
nod point - set I to decrease following error above this value
following error 2 - don't yet understand what to do with it
For Philips machine constants, these values are entered in microns and are very large (5,555mm, 2mm, 12mm). One thing to keep in mind is that the original controller stopped between lines of g-code for a set time in miliseconds, also entered in the MC. This made sure that the slide stopped at the correct point before continuing (gave time for the position loop to complete the move in the programmed place). Dunno how this would work with the trajectory planner and following errors.
I also think that your cutting problems might be related to the velocity curve of the moves calculated from your .ini file. Over time while milling a program such as your pendant housing (2 hours), the commanded feed is actually realised for a percentage of the time, while the remainder consists of moves in material at slower speeds that are the controller-derived ramps (joint.velocity-cmd trapezoid in halscope). That's bad for tool wear.
There's also the matter of the servo loop making a lot of miniscule corrections that might affect the stable operation of the drives. This is ofc pure conjecture on my part, which I'm taking from the perceptible and audible differences between various PID parameters I tested. In my case, the drives seem to be working much harder than they had, to achieve a comparatively far worse result. I can't imagine that it wouldn't have some effect on the machine's output, especially over a longer period.
Now in the case of your pendant housing, the endmill makes a lot of circular and helical moves and I'd wager that it's not always moving as fast as you programmed and that these slower feeds add up in the form of tool wear.
I can help you with your feeds and speeds for the new endmill, but first please check it for manufacturer and catalog number, or tell me whether the endmill is HSS (probably not), HSS-Co (cheaper) or HSS-PM (more expensive, superior performance). Also check for coating. These things make for a world of difference in setting the correct feeds and speeds.
EDIT: the tool info is usually there in some form on the cutter itself, you don't need the original box.
- RotarySMP
I guess if you have an absolute stop at the end of every line of code, then Ferror on linear moves is irrelevant and can be very large, as the path is always correct, just a little behind during accel and then ahead during decel.. The only place where the Ferror could cause a deviation between the commanded path, and the actual tool path would be during G2/3 curves at high feedrates.
The trajectory planner of LinuxCNC is far more sophisticated, you define a width of the acceptable tool path tolerance, my simplistic understanding is that it will match the feedrate to the machines dynamic performance to remain within those boundaries.
Good point that my sluggish tuning is probably bad for cutter life. My presence is generally bad for cutter life
Too late, I already milled it out. Worked fine at 240 mm/min. The cutter is a Chinese end mill from CTCtools.biz. No info on the type of HSS (Assume no Co),no coating and no recommended cutting parameters. At €6 pop, you can see why I am pretty relaxed about killing them. I figured I'm better off using cheap cutters, until I get enough feel for the machine to stop doing the really stupid beginner mistakes (I killed two carbides - one be jogging it into steel, the second by letting it bounce lightly on work during tool release.
