Retrofitting a 1986 Maho MH400E
7 years 5 months ago #134277 by RotarySMP
Thanks for the motivation. I am starting again from scratch, with the X axis, as I could still see a bit of oscillation at the P of 6.5 I was using. The settings I had really did suck.
When I go up for dinner, I'll post the photos of how I terminated the EXE cables in the MESA 7i77.
Mark
7 years 5 months ago #134278 by RotarySMP
What feed rate are you doing the tuning at?
7 years 5 months ago - 7 years 5 months ago #134279 by RotarySMP
Tuning the X Axis with :
Accel 220
P= 4.5
FF1 = 2.15
FF2= 0.006
With the feedrate set to 69mm/min during tuning
This is the best I have acheived.
So I am getting following errors of around 15µm at very low feed rates. That seems pretty bad to me.
I tried Accel 270, but it is worse. With max velocity of 3000mm/min, the machine has near instant accel/decel, but with pretty bad following errors.
Mark
Last edit: 7 years 5 months ago by RotarySMP.
7 years 5 months ago #134280 by Glemigobles
Replied by Glemigobles on topic Retrofitting a 1986 Maho MH400E
I tuned at rapid rates, and then when I checked the following error on slower speeds it was much better than the rapid results
7 years 5 months ago - 7 years 5 months ago #134281 by RotarySMP
The recommendations are all to start tuning slow. Could please post a screen shot of the Ferror of an X axis move at 69mm/min, so that we can compare apples to apples.
7 years 5 months ago - 7 years 5 months ago #134282 by RotarySMP
Remember I know squat about electrical stuff. Here is how I terminated each of the EXE output cables into the Mesa 7i77. I butchered the cables, chopping off the original connectors. Use a ferrule to connect an earthing wire to the shielding braid, and ran all of them to the main star ground on the bottom RH side of the cabinet, to hopefully prevent ground loops.
The lid for the pendant got made first.
The following user(s) said Thank You: Glemigobles
Time to create page: 0.925 seconds
