- Thank you received: 595
Retrofitting a 1986 Maho MH400E
- RotarySMP
9 years 3 weeks ago #99995
by RotarySMP
Good shot with the USB stick down the elevator gap. Couldn't do it again if you tried
Whn you talk of "Spindle at speed" signal, was this signal generated from that encoder, or frm the VFD, or is it just an assumed value based on the worst case time for the spindle to accelerate. The MAHO set up can't generate that signal as built can it?
Mark
Mark
- drimaropoylos
- Thank you received: 40
9 years 3 weeks ago #99998
by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
- drimaropoylos
9 years 3 weeks ago - 9 years 3 weeks ago #100000
by drimaropoylos
Spindle at speed is an control input to LinuxCnc it is binary (1 or 0) if it is 0 than the LinuxCnc holds the feeds on all axis, if it is 1 than the motion is continued again. The encoder is fed directly to LinuxCnc, and LinuxCnc synchronizes the motion for every job that needs sinc motion with spindle.
Last edit: 9 years 3 weeks ago by drimaropoylos.
- drimaropoylos
9 years 3 weeks ago - 9 years 3 weeks ago #100001
by drimaropoylos
The VFD has a relay output spindle at speed, I can connect it to mesa and connect the two signals with “and” in hall file, or in ladder. The maho originally I don’t think that it had speed at speed, I think it had timers on the controller.
- drimaropoylos
9 years 3 weeks ago - 9 years 3 weeks ago #100003
by drimaropoylos
I think that Spindle at speed is intended to be connected like this (to vfds), so LinuxCnc knows that the vfd has reached the commanded speed.
- drimaropoylos
9 years 3 weeks ago - 9 years 3 weeks ago #100013
by drimaropoylos
www.linuxcnc.org/docs/2.4/html/examples_...cha:Spindle-Feedback
loadrt encoder num_chan=1
addf encoder.update-counters base-thread
addf encoder.capture-position servo-thread
setp encoder.0.position-scale 100
net spindle-position encoder.0.position => motion.spindle-revs
net spindle-velocity encoder.0.velocity => motion.spindle-speed-in
net spindle-index-enable encoder.0.index-enable <=> motion.spindle-index-enable
net spindle-phase-a encoder.0.phase-A
net spindle-phase-b encoder.0.phase-B
net spindle-index encoder.0.phase-Z
net spindle-phase-a <= parport.0.pin-10-in
net spindle-index <= parport.0.pin-11-in
Can I put on the setp encoder.0.position-scale instead of a number, a signal that is connected to an output off ladder to scale correct the selected gear. And not connect the index
Moderators: piasdom
Time to create page: 2.193 seconds
