Retrofitting a 1986 Maho MH400E
6 years 11 months ago #150411 by db1981
Replied by db1981 on topic Retrofitting a 1986 Maho MH400E
Hello Chris and Brad,
sorry i have done a mistake, because of some lost data in my "brain memory".....
Power up the TNC on the bench again, and press 2 times the CE button. Does something changes?
All red lights instead of the one above the manual Button has to go off, and the green led in the right display has to go
to off state.
Please check the Software number on your tnc for further tests.
The following user(s) said Thank You: chris mcm
6 years 11 months ago - 6 years 11 months ago #150413 by pl7i92
Replied by pl7i92 on topic Retrofitting a 1986 Maho MH400E
hi
the 135st is a spetial thing for 1motor 3axis mill
with the dip switches you can tell the controll how the axis are in coordinate like G17/G18
also a reverse of the X is posible
the controll only got a view parameters
Parameter 01 = 2400 Parameter 02 = 1600 Parameter 03 = 2400 Parameter 04 = 4000 Parameter 05 = 4000 Parameter 06 = 6 Parameter 07 = 0 Parameter 08 = 6 (entfällt bei Maschinen der Reihe MH-C) Parameter 09 = 0 Parameter 10 = 0 Parameter 11 = 0 Parameter 12 = 7 (Softwareabhängig und kann entfallen)
its mostly a Elko that troubles the control breakdown
does your mashene got the older ls803 linescales on
that also got a special 135st version i discoverd
Last edit: 6 years 11 months ago by pl7i92. Reason: info
6 years 11 months ago #150415 by db1981
thats not full correct:
The ST has nothing to do with 1 or 3 Motors, this depends only on the Software Version and the dip switches.
S - is for 0,04mm scales 11uA, instead R ist for TTL input 0,1mm
T - is 1000 block memory, without T 500 Blocks
TNC135B has 4 fold insteed of 8 fold encoder counting.
6 years 11 months ago #150430 by RotarySMP
A little MAHO motivation....
6 years 11 months ago #150433 by Glemigobles
Replied by Glemigobles on topic Retrofitting a 1986 Maho MH400E
Jetzt mit quasi-retro techno musik!
(or should the that be just one word for all the adjectives and the noun?)
6 years 11 months ago #150435 by J Green
Replied by J Green on topic Retrofitting a 1986 Maho MH400E
Mark an others as in you'ns
Thanks for the cold morning MAHO cheer!
Has anyone figured out what the 19x2 socket is used for , located in center area of large relay board .
Any idea what a price range might be for a MH600E slotter head ? Also wonder if MH500-MH600-MH700 heads are interchangeable?
Bob
Time to create page: 1.028 seconds
