Retrofitting a 1986 Maho MH400E
6 years 11 months ago #150278 by chris mcm
Replied by chris mcm on topic Retrofitting a 1986 Maho MH400E
To J Green
I have noted what you have written. I owe you an answer. At the moment there is so much going on and I have to make some decisions. I was entirely ignorant on this subject but thanks to you and others on this forum , I am learning fast. Yes it is Spring time in New Zealand but the weather is still very unsettled. Thanks for your effort.
Cheers Chris
6 years 11 months ago #150279 by chris mcm
Hello Mark
The foot switch is a great idea. Thank you. The TNC has been partially dead since I have had the machine. One circuit board had a return trip to Germany. Still no full TNC. This no doubt sounds a dumb question. I like the idea of C.N.C Can I leave the existing controls and gear shift as they are and use a computer with Linux installed to run the D.R.O and CNC for the table motions only? This to save complication. We can add to the system at some future date.
Thanks for helping. Cheers Chris
6 years 11 months ago - 6 years 11 months ago #150280 by RotarySMP
Heidenhain LS-403 scale --> Heidenhain EXE (you can buy them from Ebay I have 602's) --> pretty much any DRO display will be able to work with the TLL output from an EXE.
Mark
Last edit: 6 years 11 months ago by RotarySMP.
6 years 11 months ago #150282 by db1981
Replied by db1981 on topic Retrofitting a 1986 Maho MH400E
Hello Chris,
i still have two ideas but to check this i have to power up my tnc first.
But this has to wait till the weekend, i am out of home for production at the moment.
i have a little reading/understanding problem:
You have got an exchange board from germany? But the eproms may be are still old?
6 years 11 months ago #150284 by eflor8234
Replied by eflor8234 on topic Retrofitting a 1986 Maho MH400E
Hauled in the rest of the Maho machines I picked up. 600P and 600E.
Also, I started dismantling one of the 400P machines. CNC conversion appears to an option without too much issue. Removed the X axis lead screw components and drilled out the bevel gear. Installing a ball screw will be straight forward and there is plenty of meat on the cast iron end cap for the table to firmly attach a servo motor mount. Y axis should be a similar operation. Not sure what I'll do for the Z axis. May mount a motor the the hand wheel location, a heavy table should eliminate most backlash using the screw that's there. Other option is to use the quill. Not a lot of travel but it wouldn't require a very big motor.
The 600E in the picture powers up but throws a code. I don't care for messing around with old electronics and find they're program size limits to be a pain. I plan to retrofit with easily available parts. I had a lathe dump an EPROM and the factory wanted $8k for a reprogrammed piece. No thanks. The Daewoo lathe now runs all day with a Centroid Acorn.
I haven't done much looking into the Indramat servos. I'm assuming they're brushed DC which would have them easy to drive with a Gecko 320X. Will see how it goes.
6 years 11 months ago #150288 by Glemigobles
Replied by Glemigobles on topic Retrofitting a 1986 Maho MH400E
J Green wrote: Glemigobles
My MH600E has table droop - sag . Was wondering where your machine is worn?
Have you considered inviting Mark over for a Three week MAHO scraping party ? :laugh: :laugh:
The most wear on my MH600E is on the vertical column. You can measure it with a micrometer to check how much thinner the side of the column is in the middle of travel when compared to the top and bottom. When milling with the vertical head, this translates to a tilt/skew in the Z axis that measures approximately 0,13 mm across the table. With horizontal milling this of course becomes the Y axis.
I face-milled the surface of an aluminum plate to create a tooling/sacrificial plate for mounting stock and minimize this error. It helped a lot and reduced the measured error down to 0,05 mm. Still, the actual wear on the ways is bad and not getting any better with use.
An alternative solution to scraping that a service technician suggested to me would be to shim the sliding member of the Z axis. But that would create problems in the ends of the travel. So, the machine should be torn down, the ways ground and scraped or just scraped (but there's turcite to think of keep all the elements in their original planes so some machining would be necessary anyway). I would also take that opportunity then to grind the table and both spindles' inner tapers, and just do a general rebuild (probably would also replace the servos with newer ones). But it's the advice of everyone I met who works in machine tool rebuilding/maintenance (and not just online posts, of which there are plenty) to scrape the ways, having them ground is not enough.
I have this sneaking suspicion that my encoder problems on the Z axis may combine with the wear on the column.
Anyway, back on topic, despite the work required on retrofitting a P series machine, they are almost guaranteed to be in better mechanical condition than an E or C of the same age just because it's far more laborious to use them so much. A CNC mill in a production environment will not be coddled and will wear much faster than a manual/mostly manual machine (just think about quill use vs programming drilling and tapping where the whole table moves up and down; it all adds up over 30+ years).
All you guys who got mint-mechanical-condition E and C series Mahos got great deals. A LinuxCNC retrofit is very doable and completely changes these machines, taking them to a new level. The learning curve is very steep, but the documentation coupled with online help is comprehensive and fantastic (you just have to get past the point of learning what they're trying to tell you :)). Anyone who has the time should go for it.
Time to create page: 4.595 seconds
