Retrofitting a 1986 Maho MH400E
- chris mcm
6 years 10 months ago #152318
by chris mcm
Replied by chris mcm on topic Retrofitting a 1986 Maho MH400E
Hello all
I have not written for a while. Greg has taken away the Indramat to replace the old capacitors. He also has taken the T.N.C unit and the screen away for a bench check to try and find the intermittent fault. I have purchased 3 Heidenhain EXE 602 D/5-4.to keep the retrofit going.
The machine can perform all its mechanical functions. I would like to have the DRO working with an independent system (hopefully) using 3 Heidenhain EXE 602 D/5-4. with the existing scales. I will report progress as it happens. It may take time as it is summer in NZ and holiday time. Greg will be busy so who knows. Cheers Chris
- Glemigobles
- Thank you received: 18
6 years 10 months ago #152356
by Glemigobles
Replied by Glemigobles on topic Retrofitting a 1986 Maho MH400E
No eBay APP ID and/or Cert ID defined in Kunena configurationHey Mark,
Is this the type of EXE box you bought as a replacement for one of your axes?
Can I plug this (or something like it) into my Mesa board and wire the Z/Y axis scale through it, while leaving the X and Y on the original 3-axis board?
I'm wondering if replacing the EXE on the Z axis would fix my problem of the signal getting lost sometimes and this looks like a cheap-ish potential fix (I posted a link to the most expensive box listed atm because it looks like new old stock).
I've already tried cleaning the scale and replacing the reader head and the same problem of unreliable operation in the Z axis persisted. Maybe the old EXE board is failing, or generating a weak signal which somtimes isn't picked up by the controller. I used to have an issue where the signal wouldn't be read at startup occassionally, but it eventually worsened to the point that sometimes it's lost while the machine is working. Which is why I haven't worked on it in auto for a long time, using it sparingly to drill holes or perform simple manual operations. I'm afraid of the signal going out and crashing the spindle into something before a following error triggers the E-Stop.
Marcin
Marcin
- akb1212
- Thank you received: 12
6 years 10 months ago #152357
by akb1212
Replied by akb1212 on topic Retrofitting a 1986 Maho MH400E
Hi Marcin,
Splitting encoder signals is possible. But needs to be done propperly (after it has been converted to quadrature!). And splitting the signals from the scales is NOT possible without doing propper perparation, as is therefore not recommended. The signals comming out of them are very low current signals (22uA), and needs to be terminated correctly in to ONE reader, and can not be splitt by simle means.
It's is a lot easier to split the quadrature signals coming out of the EXE-boxes. But I recommend using an active splitter, like the one Mesa is offering. Although it wold probably work without as well, for testing anyway..... balanced wiring will make this more reliable.
An easy way to confirm if the error is in the converter you are using now is to switch converters between channels (switsh inputs AND outputs!). Then verify if the error moves with the converter og stays at the same axis. If it moves with the converter you can assume it's faulty and needs to be replaced, and a new EXE-box will fix your problem.
If not you need to do something with the read head or similar, and getting a new EXE-box wil not fix your problem.
The boxes you are linking to is similar to the ones I have, and should work.
Anders
Anders
- Glemigobles
6 years 10 months ago #152361
by Glemigobles
Thanks for the quick reply Anders!
I'm going to try swapping the inputs and outputs this week to see if I can replicate the signal loss on a different axis.
I guess before buying an EXE box it'd be a good idea to go through the Heidenhain docs on their website and see if the components will be compatible with each other.
There are also original 3-axis EXE boards available on ebay.de but they're somehow more expensive per module than buying three separate boxes for each axis. That's a shame because that would be a very easy replacement.
- RotarySMP
- Thank you received: 595
6 years 10 months ago - 6 years 10 months ago #152364
by RotarySMP
The single channel EXE's offer a number of advantages.
- They are built like brick outhouses. The housing must be indestructible.
- They only need 5V. Whereas the 3 EXE board needs both 5v and 12vdc supplies.
- 602 EXE's (at lest the two I have) have the differential signals wired in the output cable, so you should have better noise resistance. The three EXE only brings out the single end signals.
- They are cheap and easy to replace.
-They all seem to have the M23 connector for the signal input. You see a variety of output cables from Heidenhain. Heidenhain wiring is fantastic. Double shielded with very robust conduits.
- Heidenhain seems to use consistent wiring colors across the decades and products. Here is my wiring on my 602D/1-5
Heidenhain seems to offer versions with either 5µm resolution, or with 1µm resolution. I ended up with one of each. Doesn't really matter for my level of machining. I can snap off a carbide end mill on the vise just as easily with either system. You just need to edit the INI for
instead of 1000 for that axis.
The 602/1-F has only 5µm resolution
whereas the 602D/5-F ouputs 1µm resolution. I wonder whether the D means it has the extra interpolation?
I only paid about €50 for each. Both work perfectly. Some have ouput connectors and some have cables. I went for ones with output cables and hacked whatever connectors were on the ends and wired them straight in the MESA 7i77. I understand the appeal of finding three with the same output terminal connectors and making a break out connector for the 7i77 so they can be plugged in
Mark
ENCODER_SCALE = -200
Mark
Last edit: 6 years 10 months ago by RotarySMP.
The following user(s) said Thank You: Glemigobles
- RotarySMP
6 years 10 months ago #152365
by RotarySMP
Hi Anders, I didn't see Marcin wanting to split encoders signals to two users, but just to replace a single channel of the 3 axis EXE board. The 3 Axis board has three electrically independant EXE's. There is nothing shared between the three channels other than the PCB fiberglass.
I agree he should switch input and output cables for two axis, and run the machine to isolate the fault between encoder and EXE though first.
Mark
Mark
Time to create page: 4.464 seconds
