Retrofitting a 1986 Maho MH400E
6 years 10 months ago #153115 by RotarySMP
That is good to know.
You have to post some pictures of your A axis.
Mark
6 years 10 months ago #153124 by J Green
Replied by J Green on topic Retrofitting a 1986 Maho MH400E
Wishing all of you Linux CNC ers the seasons best and a even better New Year
Hanno - You are aware the LS 403 scales have a ( RM on the scale label ) reference mark near each end of the glass scale, for near end of travel use? Don't know if you have used them for homing and or soft travel limit .
How do you guys find such clean Mahos? Yes -- More pictures ! Please
Mark -- Looks as if the tool setter is working now. Good to hear. Wondering what the next addition is going to be . Agree with you about faster servo speeds. To me it's the difference of a Umog vers a Ferrari in that do you want to get there an back or look stylish while broken down on the road. I hate walking home!
Did you ever manage to squeeze the Maho into your warm shop ? Hope we don't have another winter white-out of MAHO progress.
:laugh:
Bob
6 years 10 months ago #153152 by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
hanmon wrote: Servus Mark,
"Probieren geht über Studieren" ;-)
The glass-scale says 370mm on its number plate so
I gained travel from -1/251 to -11/257 (ini-file) by simply sliding the adjustable stops to their end position. There is still 2mm play to the switch. I think one could bring this up to 100mm or more if pushed to the real mechanical limits by moving the stoppers.
Hanno
If you really need that little extra travel for a specific job you can wire a button that shorts the limit switch and use it only when the program needs to.
Soft limits are going to save you from crank that axis out of limit switches. Limit switches ere going to cut the power from the servo motors in case of runaway and hard limits going to absorb the energy from 600 kgr head going full rapid.
6 years 10 months ago #153197 by RotarySMP
OT, but I did a couple of casting sessions before Xmas. SWMBO is a Beatles fan, so I cast a Paul Mac statue as a pressie for her. The STL model is in the Thingiverse. It was scaled up 50%, and a close fitting flask also 3D printed, to use as little investment as possible. Unfortunately I have no way to pull a vacuum and degas the investment.
The next session was a bit of aluminium, doing parts for Julian HG's , modular flask design. These arent very good. I had the sand a little dry, and had a lot of break out pulling the pattern.
Once the furnace was hot enough, I switched to the oil burner, and did my first successful iron pour. This is a face plate for the Boley 4LV lathe. There are three minor voids visible, and the surface finish is very rough. I didn't use any facing sand with carbon dust in it. The core was made with sugar water bonded sand and baked. The carbon in the core made for a pretty good surface finish in there.
There is an extra boss cast into the front to grip it in the four jaw for boring out and threading the bore for the spindle nose thread.
Mark
6 years 10 months ago #153226 by J Green
Mark
Impressive foundry work you are doing there. Looks as if those who cast dispersions about a broken MAHO purchase can now go pound sand ,or be redirected into mulling sand.
This side of the Atlantic pond, pouring cast iron is fairly rare at the hobby level . Cast iron requires a lot of heat and the stuff added to the melt are hard to get in small amounts. For a vacuum , would a water aspirator be of any use? Andy P. might be of some metallurgy help if you start cooking up various flavours of metal.
When are you going to show a photo of the sand muller? If you are so hung up on form over function then slap lipstick on it.
Wishing the best in the New Year
Bob
6 years 10 months ago #153258 by andypugh
Replied by andypugh on topic Retrofitting a 1986 Maho MH400E
J Green wrote: For a vacuum , would a water aspirator be of any use?
A recent idea on Hackaday for degassing epoxy was one of these.
www.amazon.com/dp/B07Z5W5JD1/
I modified a 12V tyre inflator (by adding a tube to the inlet) when I wanted a vacuum a little while ago.
Moderators: piasdom
Time to create page: 0.303 seconds
