- Thank you received: 40
Retrofitting a 1986 Maho MH400E
- drimaropoylos
6 years 9 months ago #155465
by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
This is what you have adjusted?hanmon wrote: Hi drimaropoylos,
I adjusted the wedge on the X-axis.
Measured the original unmachined spacer to have 10,48mm.
Made a second test-spacer out of a tube and turned it down to 10,40mm and 10,32 which was enogh.
Turned the original spacer down to that 10,32mm then.
According to the manual a spacer reduction of 0,13mm minimizes the play about 0,001mm,
whatever that means and how they measure that.
- hanmon
- Thank you received: 23
6 years 9 months ago #155476
by hanmon
Replied by hanmon on topic Retrofitting a 1986 Maho MH400E
yes.
The drawing looks different in my documents.
Will post a picture tomorrow.
The following user(s) said Thank You: drimaropoylos
- Mccartymachine1
6 years 9 months ago #155488
by Mccartymachine1
Replied by Mccartymachine1 on topic Retrofitting a 1986 Maho MH400E
I still have not figured out a way to get a digital read out on the screen showing the position of the rotary table. Mine also has the rod271 encoder. My machine is a mh600c and I am running a 7i77, 5i25, and the original servo drives. I got some documentation on the rod271 but the wire colors do not match what maho used. Don't want to connect wrong and fry encoder. Need help with wiring and ini please.
- J Green
- Thank you received: 24
6 years 9 months ago #155506
by J Green
Replied by J Green on topic Retrofitting a 1986 Maho MH400E
Hi Mccartymachine1
Am sorry I can't answer your question.
My thoughts are it would help others , who may have a answer, if you could post your ini. file an the ROD 271 doc. I think the ROD 271 has TTL output so should be able to wire directly to your 7i77. Meaning that it doesen't require a Exe-Bd as your Heindehain scales do. Your documentation will note what the TTL voltage level is. Might be useful to get a Photo of the dissembled connector showing the pins an pin wiring. Darn pastel colours an OEM parts can be a bother.
Also I guess you may want use of the index - reference mark and how to off set it for homing. Especially if the rotary table is servo controlled.
What are you doing to cause the table hydraulic brakes to release? If the rotary table is servo controlled then might be worthwhile to also include your HAL file . What user interface are you using ?
What the heck throw in a photo of the rotary table too ! Please
Stay warm
Bob
P.S. Forgot to mention -include a MAHO schematic section showing the Rod wiring. Don't think they used the differential TTL signal , that to me is just asking for trouble. Could have been due to how Philips control boards were designed.
Stay warm
Bob
- RotarySMP
- Thank you received: 595
6 years 9 months ago #155513
by RotarySMP
That is useful to know. Thanks.
Mark
drimaropoylos wrote: It is a MH600E, the new ball screw is from a MH400E x axis. Exactly the same dimensions for y axis of MH600E
Mark
- hanmon
6 years 9 months ago #155517
by hanmon
The following user(s) said Thank You: drimaropoylos, Azzrael
Moderators: piasdom
Time to create page: 1.322 seconds
