- Thank you received: 40
Retrofitting a 1986 Maho MH400E
- drimaropoylos
8 years 11 months ago #101663
by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
First check in and out voltages on the bridge rectifier 6v1 and then the transformer. But be careful, if this drop in the voltage is caused from a shortcut then there is a chance something to blowup. Disconnect one of the dc outputs of the bridge rectifier and put an amperemeter.
- drimaropoylos
8 years 11 months ago - 8 years 11 months ago #101664
by drimaropoylos
Test all the possible combination off rails and exe input to ensure the behavior is the same on all the rails and output of the exe.
Last edit: 8 years 11 months ago by drimaropoylos.
8 years 11 months ago #101665
I would try measuring the voltage across a load resistor.
Replied by andypugh on topic Retrofitting a 1986 Maho MH400E
RotarySMP wrote: How do I go about measuring the 11µA sine waves comming off the scales? With my multimeter on mA, its lowest scale is 400mA. Do I measure between I1+ to I1- or one pole to ground?
- RotarySMP
- Thank you received: 595
8 years 11 months ago - 8 years 1 month ago #101684
by RotarySMP
Looks like I wont need to measure the 11µA sine wave at present. The EXE board also has +12V test points.
Since the MAHO wiring diagram only showed 5V supply to the glass scale EXE A/D signal processor, I wrongly figured the 12V wasn't needed. Since the MAHO wiring diagrams are wrong on the wiring colors, I connected up 12V to the test point, and sure enough,
Cool, if anyone else wants to interface Heidenhain LS403 glass scales through a 229 281 01 EXE board, the pin out is:
+12V - Red
+5V - Brown
0V - White
A - Green
B - Blue
Z - [need to confirm this, but I think it is grey.]
I'll take 12V from the ITX PSU and add terminals to wire all three EXE'S into.
+12V - Red
+5V - Brown
0V - White
A - Green
B - Blue
Last edit: 8 years 1 month ago by RotarySMP.
- RotarySMP
8 years 11 months ago - 8 years 11 months ago #101786
by RotarySMP
Last edit: 8 years 11 months ago by RotarySMP. Reason: Better photos
- Thank you received: 7491
8 years 11 months ago #101801
Replied by tommylight on topic Retrofitting a 1986 Maho MH400E
Looks awesome for sure!
Regards,
Tom
Regards,
Tom
Moderators: piasdom
Time to create page: 0.201 seconds
