Retrofitting a 1986 Maho MH400E
8 years 11 months ago #101988 by tommylight
Replied by tommylight on topic Retrofitting a 1986 Maho MH400E
You should check if something connected to that scale is getting hot with time, like the EXE ( as far as i remember reading here ) or check for power supply ripple, but since that occurs only on one axis i doubt that would be it.
Check also if there is any possibility to measure the voltage going to the LED on that scale ( or is it a bulb ???? ), LED tend to lower the intensity as soon as they start to heat.
8 years 11 months ago - 8 years 11 months ago #102004 by RotarySMP
Good inputs. Thanks.
I reterminated the two ribbon cables. Need to take a break and recheck all my work before I install them. Is there an industry standard way to terminate the unsed wire ends? I'd just neaten them up and bundle them with heatshrink.
Attached are the two pin maps I have so far.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
Mark
Last edit: 8 years 11 months ago by RotarySMP.
8 years 11 months ago #102007 by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
How the relay board gets the information for the feed on the axis (Spindle and Feed stop)? How the 4A1 relays is controlled and where that relay is?
8 years 11 months ago #102017 by RotarySMP
Good question. At this time, I have no clue. I figured I'd wire it up, and then see if I could figured out the logic, and see if I needed it and if I could integrate it into LinuxCNC.
Mark
8 years 11 months ago #102079 by andypugh
Replied by andypugh on topic Retrofitting a 1986 Maho MH400E
RotarySMP wrote: I reterminated the two ribbon cables. Need to take a break and recheck all my work before I install them. Is there an industry standard way to terminate the unsed wire ends?
Too late now, but to connect screw terminals to box-headers I use M20 individual wire crimp headers.
uk.rs-online.com/web/p/pcb-connector-housings/6812874/ (ignore the picture, the link is to a 2x12 plug)
I don't think that they do them full-width for 50 pin headers, but you can fit them side-by side and/or glue them together.
You need crimps and a crimping tool, but one advantage is easy re-wiring.
8 years 11 months ago - 8 years 11 months ago #102111 by RotarySMP
I do have the crimping pliers from Engineer for them, and used them on my 3d printer, but figured the ribbon cables were already here so I'd reuse them.
Many of the pins are also connected to screw terminals on the PCB, so there are probably less than 20 sockets to populate if you went with your suggested connectors.
Mark
Moderators: piasdom
Time to create page: 0.277 seconds
