Retrofitting a 1986 Maho MH400E
8 years 11 months ago - 8 years 11 months ago #101967 by RotarySMP
Thanks John, It could well be a noise issue, but I find it weird that it is very responsive when you turn the machine on, then gets a bit flaky, where it loses pulses, and then stops reacting completely. The X seems rock solid. Z I haven't tested yet, as the brake is on, and I was too lazy to put 24V on it.
I also need to look again at that Indramat start circuit I added. It is not yet fully wired in, but the Indramat is enabling the drives when the start switch is pushed. Shouldn't be, as I thought I opened that crcuit form the original wiring.
Went to the Dr to have a check up on that crushed toes. Still healing very slowly. They look terrible. I was too unmotivated to redo the wiring on the 7i84 yesterday.
I had been planning to do the physical buttons on the control planel with tactile switches. I have been thinking about them and trying to come up with a good way to install them.
tinyurl.com/ydbh2qv3
My slow boat from China arrived, and I still had no good plan.
A couple of months ago I also ordered an E-Stop button from Ebay China.
tinyurl.com/ybdazu5g
Turn out this uses the same ZB2-BE102c contact blocks (or at least copies of the schneider contact blocks), as MAHO used on their E-Stop switchs. I can get the ZB2-BE102c (NC) schneider contact blocks from RSonline, but the equivent (NO) ZB2-BE101C cost 8x as much. Again china Ebay to the rescue. The same vender I already got the E-Stop switch from, has 40 contact blocks for €32 which is unbeatable. Since the laser guy won't be cutting my contol panel parts till later this week, yesterday I drew up some more sheet metal to be lasered to mount the buttons to the control panel to activate contact blocks. Since these are more robust and have screw connections, I thing it should be a better solution for the panel wiring.
The RJ45 - VGA adapters also turned up.
My Maho is currently in my basement garage. This is not ideal, as it is normally my grinding, welding, sandblasting, painting area. The room behind the garage is the machine shop, with the lathe, band saw, bench, and currently the little Deckel engraver/mill. I would really like the MAHO in that room, but the door is only 69cm wide and 196 tall. I had given up on moving it, as the control cabinet would have to come off the MAHO, there are no disconnects, and I really didn't want to disconnect all wiring. Looking closer, I think there is enough free length in the wiring to unbolt the cabinet, and swing it round directly behind the mill in line with it to get through the door. Then I would only need to remove the table and cross slide. It will be a very tight fit as the control cabinet is 68cm deep, the doorway is 69cm wide, and it is a very thick concrete wall so alignment will be critical.
I don't have much space, so the MAHO was always going to have to go against a wall, and I was going to make a transport dolly to be able to pick it up and roll it out to access the electrical cabinet, but might make an adjustable one like this so I can also use it on the Lathe and Doall.
www.nwnative.us/Grant/shop%20articles/mtd/projectWebPage.html
Mark
Last edit: 8 years 11 months ago by RotarySMP.
8 years 11 months ago - 8 years 11 months ago #101968 by RotarySMP
The forum software sometimes corrupts photos I upload.
I had a bit of a spending spree, picking up Sandvik 100mm insert face mill
A couple of Hydrolock holders.
and some Weldon and ER 32 holders plus a couple of mount boards.
Mark
8 years 11 months ago - 8 years 11 months ago #101969 by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
Seems like the common for 5 volt or for 12 volt is missing from the exe card and the voltage off the common slowly drifts from the 0 volt to the Vcc over time.
Last edit: 8 years 11 months ago by drimaropoylos.
8 years 11 months ago #101970 by drimaropoylos
Or the connection of 12 volt on the test pins is not stable
8 years 11 months ago #101971 by drimaropoylos
or the test pins are not connected directly on Vcc, but a resistor is between
8 years 11 months ago #101972 by RotarySMP
Good inputs. Thanks. I did tie the 12V ground from the PC PSU, which is powering the EXE, to the 5V ground from the little PSU which is powering the 7i77. However, I can recheck the ground to that specific channel.
There is no resistance between the test pins and the VCC pins.
Mark
Moderators: piasdom
Time to create page: 1.271 seconds
