Retrofitting a 1986 Maho MH400E
8 years 11 months ago #102138
Replied by andypugh on topic Retrofitting a 1986 Maho MH400E
- drimaropoylos
- Thank you received: 40
8 years 11 months ago #102139
by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
Thank you for that, the size is 3,5 mm. like those
www.amazon.com/Diameter-Chrome-Steel-Bea...mm+Bearing+Balls+G10
8 years 11 months ago #102140
For a ballscrew you want to be more accurate than just "3.5"
The vendor in the link I sent does them in .001" increments, but only around a 1/8" nominal size.
www.amazon.com/s/ref=nb_sb_noss?url=sear...+Screw+Balls+100+pcs
- Thank you received: 5334
8 years 11 months ago #102141
Replied by PCW on topic Retrofitting a 1986 Maho MH400E
More than that I think its suggested that the balls be in alternate sizes (spacer balls and load bearing balls)
8 years 11 months ago #102142
I think that alternating might be done also when fitting oversize balls in order to keep the train length the same.
- drimaropoylos
8 years 11 months ago #102144
by drimaropoylos
The micrometer reeds 3,499. The only solution is to send samples to the supplier and he will responsible to proper measure the balls with the his advanced measurement tools, and then send me the proper sized replacements. Or even better solution is to find some company on Europe to send the whole ballscrew, to replace all the balls and seals. The only one that I have found has never answer back.
Moderators: piasdom
Time to create page: 0.179 seconds
