Retrofitting a 1986 Maho MH400E
9 years 1 month ago - 9 years 1 month ago #99078 by RotarySMP
Over the weekend, I received more way oil, and filled the tank, just in case I had a low level warning. It made no different to the pin 253 state, so I guess it was already off the low level switch.
I also disconnected the CGA graphics cable (19x21). The monitor response (snow and diagonal rolling) is the same regardless whether the cable is connected or not.
I used my Multimeters frequency and oscilloscope functions to check for a H-Sync on the graphic card output. <edit> I redid the measurement with a colleauge, and there may be an H-Sync signal there. My Multimeters Osci function may just have an inadequate sample rate to confirm that.
Does anyone have a Phillips 432/10 Manual, please?
Mark
Last edit: 9 years 1 month ago by RotarySMP.
9 years 1 month ago - 9 years 1 month ago #99270 by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
Hi, I am in the process off retrofit a maho mh600e and from the drawings RotarySMP send me (thank you for that), I have concluded that the 3 inner cams on the motors are for the machine to know when the machine reached the destination and stop the motor. The next cam is to slow down the motor when close to the middle gear so is not overshoot, it only works if 11k3 is enabled, so if we want to go to the middle gear we must enable the 11k3 to slow down the motor right before reaching the middle. The last cam is to tell the controller to go right or left to get to the middle gear. You must experiment to find the time that is needed to get from one position to the next and reverse the spindle motor if that time is passed and the position is no reached, so the teeth of the gears have a chance to engage. How is the proper way to show the ladder logic here to help others with mahos and other machines with gears?
Last edit: 9 years 1 month ago by drimaropoylos.
9 years 1 month ago #99272 by drimaropoylos
9 years 1 month ago - 9 years 1 month ago #99313 by drimaropoylos
S80, s100, s125… s4000 is the commanded speed from the hal, the left (backgear) gear is commanded first to go to the proper position. Once on the position, the second (middle) gear goes to the proper position. And then the third. If no position is reached or the gear is not passed from the middle position then the 11k9 and 11k10 toggles to help the gears to mesh
When everything is finish ok the G-ok tells the controller commanded speed is ok
The times are not tested on the machine, I will start from hi values and shorting them with tests
9 years 1 month ago #99356 by RotarySMP
Awesome work Drimaropoylos. It must have taken you ages to work through and record the timing. Thanks for sharing this. Did you draw the ladders for all 18 gears already?
So far I have only read the docs on Classic Ladder, but haven't actively played around with it, so I am struggling to follow the ladder logic.
Do I understand that correctly that MAHO cam feedback switchs 11S1-5 / 11S6-10 / 11S11 -15 are assigned G[stage] in your Ladder? Would I be able to rename those 11S[n] to keep it consistant with my MAHO's wiring diagrams? You list five colors, but only four cams are output to the Phillips as far as I can tell.
Those fourth cam status in each group (11S4, 11S9 and 11S14) are not input to LinuxCNC through the MAHO relay board, but do connect to pins 302, 304 and 306. Does that mean that the MAHO relay board slows the motor without control input?
I got my new oscilloscope, and had another look for H-Sync and V-Sync signals out of the Phillips. Nothing. there. With the help of your Ladder, my need to get the Phillips running is diminishing. I switched to toubleshooting the E-Stop chain to see if I can find out why the Hydraulic pump doesn't start.
I am getting closer to to just removing the Phillips and going straight to LinuCNC! I started setting up the PC so I can load LinuxCNC and configure the 5i25,7i77 and 7i84. Unfortunately I am having trouble getting a bootable image on the USB stick. Last time I loaded LinuxcCNC, I used Rufus, but that program now triggers my firewalls MALWare filter. I used isotosub, but it wont boot.
I've attached the modified wiring diagrams to reflect the MESA card's replacing the Phillips 432.
Mark
The following user(s) said Thank You: vibram
9 years 1 month ago #99357 by RotarySMP
Here are the other four modified wiring diagrams...
There is one more I still need to do (Sheet 6) once the right way to wire the Indramats axis enable switchs becomes clear.
Mark
Moderators: piasdom
Time to create page: 2.513 seconds
