- Thank you received: 595
Retrofitting a 1986 Maho MH400E
- RotarySMP
9 years 1 month ago - 9 years 1 month ago #99688
by RotarySMP
I need to test and see of pushing both buttons at once would work, as if does is it will need to least change to anything.
Today I cut a peice of scrap aluminium as a mounting board for the various electronics. The ITX PC and 7i77 will go on the mounting board,
while the Heidenhain EXE mounts on the side wall,
and the 7i84 on the cabinet door under the MAHO relay board.
While waiting for the "Verdrahtungskanal" (the wiring chanel with the comb wire openings) to arrive, I need to design and 3d print a DIN rail adaptor to mount the ITX PSU, the harddrive and the Heidehain EXE mounts.
The 17" touchscreen monitor arrived today as well, so I can start measureing and laying out the control panel and housing. I friend of mine has contracts with a laser cutting company in Bratislava, so i'll be getting the sheet metal laser cut.
How is your gearbox ladder coming along John?
Mark
Mark
Last edit: 9 years 1 month ago by RotarySMP.
- drimaropoylos
- Thank you received: 40
9 years 1 month ago #99691
by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
Tomorrow I will start making the new configuration according to your wiring diagrams.
Your machine does not have the slightest sing of use, not even dust on the cabinet. It was from a school?
- drimaropoylos
9 years 1 month ago #99693
by drimaropoylos
Do you have list for the capacitors on the amplifier that needs to be replaced so I can make order?
- RotarySMP
9 years 1 month ago - 9 years 1 month ago #99700
by RotarySMP
100µF 40V 85° 20% Elko (8 of)
2200µF 40V 85° 20% Elko (3 of)
You will need to check those values against your Indramat. Your 600E motors are probably more powerful than my 400E's.
Yep. It came out of the HWK Passau in Bavaria. I have done a fair bit of cleaning, but it was more dust than swarf and coolant.
Mark
Mark
- drimaropoylos
9 years 1 month ago #99723
by drimaropoylos
Good morning, the capacitors are axial or radial arrangement
- drimaropoylos
9 years 1 month ago #99724
by drimaropoylos
I thing that you should shield the exe board from electrical noise. The output of the exe board is digital (on-off quadrature) but the input is sing wave from the heidenhain scales, any noise in this signal is perceived (from the exe board) to be motion
Moderators: piasdom
Time to create page: 0.345 seconds
