Retrofitting a 1986 Maho MH400E
7 years 9 months ago #124635 by hanmon
Replied by hanmon on topic Retrofitting a 1986 Maho MH400E
Still waiting for my last cable/adapter order so nothing done the last few days, too.
Yes, a couple of days after I had bought the 400E I "accidentally" bought a 400C (4th Axis) as sole bidder on ebay. I'd like to sell because of the limited space in my shop, but I not necessarily will till it is a really nice machine.
ATX-PSU: One separate for both cards, EXE and MESA.
LS403: of course, I could send you a read head of the 400C, but as already stated, this won't solve anything as the axis works fine with a different EXE. So read head and scale should be ok.
I don't know when my machine will be ready to run, but we could do things the other way round.
Mark, you could send me your EXE and I'd check a few things !?.
That your ATX did not work, I cannot explain. You properly interconnected grounds/minus ?
Generally they are designed to reliably power mainboards and provide x times more current than you really need.
A note on git: Only authorized users can modify content of a project. You would still have the control.
Hanno
7 years 9 months ago #124644 by J Green
Replied by J Green on topic Retrofitting a 1986 Maho MH400E
Shop getting crowded and limited space ? I feel your pain + one. Started with one MH600E that has a straight/flat table and few days later noticed another MH600E that has B axis. Then a few more days later saw a MH600E2 that has 20 tool tool changer and the next series Indramat servo drives. Spent most of that summer to beginning of fall dragging the three machines back to my 2 car shop. My thinking for the two MH600E machines was spare parts and the B axis . My thinking for the MH600E2 ? It just looked lonely !
Now I am trying to get heat and electrical power an lighting into the garage-shop .Also need to rig up a 3 phase 380 volt power supply as most homes in the US are only single phase 220 / 120 volt. They just don't trust us with 3 Phase power.
Your note on github: of only authorized users can modify content of a project sounds great.
Hope the parts order shows up sooner than you expected.
Think Maho Green
Bob
7 years 9 months ago #124668 by hanmon
A fellow sufferer ;-)
B-Axis+spare parts, exactly what I thought when bidding.
@Mark:
The ATX PSU's voltage tolerances according to specs is 5% which equals to 4,75-5,25 V and 11,4-12,6V an should be the same that MAHO requires.
I would try to power the EXE with the PC's PSU again.
Hanno
7 years 9 months ago #124719 by RotarySMP
Everyone thinks I am crazy for buying a 1.2 ton unservicable mill. I can imagine your relatives and friends trying to get you committed for buying three :)
7 years 9 months ago #124724 by hanmon
I think I can top that.
I bought a fork lift to be able to unload and move my machines.
I just wanted to be independent from my neighbour with his tractor ;-)
My lathe weights 4.5t. That was really crazy to get it into position using two pallet trucks. ....welcome to this madhouse ;-)
7 years 9 months ago #124725 by RotarySMP
A forklift. Nice. My basement is too low for anything like that. I moved my lathe in on ion bars.
Moderators: piasdom
Time to create page: 3.210 seconds
