- Thank you received: 24
Retrofitting a 1986 Maho MH400E
- J Green
7 years 9 months ago - 7 years 9 months ago #125294
by J Green
Replied by J Green on topic Retrofitting a 1986 Maho MH400E
Hanmon
As I remember ? The Lub pump cycled at machine start-up and cycled after some time ( amount of movement ) period t , but also cycled due to the axis movements being short in length.
Zeeson Muhr ( Sp ? ) converted his Mikron mill and wrote a program for lubrication cycle timing
I saw the program in the Wicki or somewhere else in the .Linux CNC site.
If you can't find It ----let me know and will try to stumble across it again.
Bob
Bob
Last edit: 7 years 9 months ago by J Green.
- J Green
7 years 9 months ago #125299
by J Green
Hanmon
It is written by Zeeshan Munir
Located in" Linux CNC Documentation" under Centralized Lubricator .
Hope this helps
but not sure if it has the extra cycling part that Philips did for many short moves.
Bob
Hope this helps
Bob
- hanmon
- Thank you received: 23
7 years 9 months ago #125308
by hanmon
Replied by hanmon on topic Retrofitting a 1986 Maho MH400E
thx a lot !
I took a short look at the code.
It seems to build up pressure for 10s and if there is no fault, low fluid level or pressure loss, it keeps running for 50s more to then idle for 12min.
This cycle starts every time when machine is on an the spindle is running.
I will take it as is and eventually modify it later.
Hanno
thx a lot !
Hanno
- RotarySMP
- Thank you received: 595
7 years 9 months ago #125400
by RotarySMP
Hi Hanno,
Good progress, but remember, photos or it didn't happen
I'll post that clover leaf program later.
If you work in the garage at 2°C you are a tougher breed than me.
I also used that same PID tuning procedure and found it very helpful. I think I'll have to retune Y once the replacement exe is wired up, as I never got a good tune, and the axis drift was probably a factor there.
We had a discussion about the lube system at some time. I thought in here. My one has the automatic pump. It runs for something like 30 sec at start up, and then again every 20 minutes.
Mark
Mark
- RotarySMP
7 years 9 months ago #125411
by RotarySMP
Here is the code which draws a cloverleaf each 15 minutes.
- J Green
7 years 9 months ago #125412
by J Green
Mark I remember when Zeeshan converted his Mikron (about size of a MH500e) a discussion that the Maho also had a extra Lubrication cycle for short an small moves . Think I saw it in some of the Philips 432 machine parameters .
Are you getting another EXE board ? Or what is the latests in the Y axis problem.
Could be very interesting to compare the PID values you and Hanmon use for the initial servo tune.
It will not be very much time before you an Hanmon have initial conversion done and can start on the fine tuning part.
Stay warm
Bob
Stay warm
Bob
Time to create page: 0.280 seconds
