Retrofitting a 1986 Maho MH400E
7 years 8 months ago - 7 years 8 months ago #125533 by RotarySMP
The Input is +/-10V, between those two pins. If LinuxCNC commands speed in one direction it will apply +V on e101, and - V on e102. To hold position it will be 0 voltage between the two pins. For motion the other way it will be applying -V on e101 and +V on e102. So if you connect a 1.5V battery between those two pins you should get about 1/6th speed in one direction. Reversing the battery should reverse direction.
Mark
Last edit: 7 years 8 months ago by RotarySMP.
7 years 8 months ago #125549 by hanmon
Replied by hanmon on topic Retrofitting a 1986 Maho MH400E
the luby.py (Centralized Lubricater) didn't want to get loaded.
The error was "no such file or directory". For hours I messed around with $PATH, bash_profile, relative paths, absolute paths until I finally noticed that there were the characters "^M" at the end of each code line in lube.py. Somewhere in the process of downloading and copying the file over to the LinuxCNC-PC, editing with different editors vi, mousepad and kate they must have been automatically added. Nevertheless, it works as expected.
I ran Mark's clover-leaf code and I'm glad to see no drift after 1 hour (4 passes):
@Mark: How is the change to the new 602-EXE going ?
Swapped the axis labels:
The following user(s) said Thank You: Glemigobles
7 years 8 months ago #125581 by hanmon
You want to see pictures of the progress ?
Here they are.
The wiring is almost complete.
Made a ground rail where I will mount an additional piece of sheet-metal against EMI over both MESA-cards when the 4th axis is wired up.
Almost everything nice and clean.
I "organized" two DIN PSUs with 1% voltage tolerance.
The difference to the ATX-PSU is only..... it looks better:
7 years 8 months ago #125582 by Glemigobles
Replied by Glemigobles on topic Retrofitting a 1986 Maho MH400E
Hi Hanmon,
Great to see your progress on the machine! I love how you managed to fit that sawn-off chassis in place of the original computer. I also want to repurpose my old desktop PC for the retrofit, even if it seems a bit wasteful (an i7 processor seems like overkill for the low speeds of the Maho); it seems like a move that ensures high quality components with long operating life where it really matters. It's already a PITA to troubleshoot a PC when something goes wrong, it would be even worse when the computer is a part of a complex assembly.
Mark, reading about your EXE problem it's even more impressive that you managed to do that retrofit! Thinking about it, your machine didn't work to begin with but you replaced the computer, interfaced everything and now you're successfully troubleshooting problems with faulty hardware. Your background as an aircraft service engineer must really be helpful to keep a cool head and proceed to methodically test everything. This shows especially in how you measured the axis drift. I guess that particular problem also helps to explain some of the problems you've had with machining in this thread. It would easily ruin my work to have that happen.
7 years 8 months ago #125583 by hanmon
concerning the position of the PC I would do it differently.
In my kiosk-control-panel there is a lot of unused space and there actually was a pc in the back. I now had to draw 5 cables through the conduit. 2xUSB, DisplayPort, Serial4pendant and 3,5mm Audio. If you use/place the PC inside the control housing you'd only have to draw the 2 D-SUB cables when using the 7i74, in Mark's case only one D-SUB.
Beside the logical separation, I think this would be much better due to EMI.
The MH400C indeed had the Philips controller located inside the control panel.
7 years 8 months ago #125584 by J Green
Replied by J Green on topic Retrofitting a 1986 Maho MH400E
Hanmon
That wiring looks as if you prefer to do it correctly the first time, verses poking around later trying to find what wire isn't making contact. Good job, and thanks for the photos.
Question
Just below the ground rail is a red wire and three small pink wires going into some type of block having three orange stripes on the outside. What is that --- a wire junction block?
Mark
Sorry I can't offer you anything more than warm wishes for getting the 602D EXE problem sorted. Who would have thunk ---Heidenhain going to chick designer wire colors . Has to have been a marketing department decision.
Glemigobles
" the low speeds of the Maho " Granted a MAHO CNC mill may not be as fast as a SR 71 Blackbird , but what is / would be a fair comparison to machines built before -say year 2000 ?
Just wondering -- and No I don't how they compare to other similar CNC mills Just interested in what your thoughts are..
Bob
Time to create page: 1.406 seconds
