Retrofitting a 1986 Maho MH400E
- R2AIV
7 years 8 months ago #126366
by R2AIV
Replied by R2AIV on topic Retrofitting a 1986 Maho MH400E
Hello! First question is about link gearbox library from github to LinuxCNC. How i can do it?
I was analize schematic of MH400T and don't understand how tool change works. I mean, it works like simple trigger with two states? I found time-relay in relay box, in schematic it corresponds to tool change. What is role of this relay? And, finally, i want to ask you: can you send me image of your LinuxCNC (HAL and ini)? More is better. Thank you!
PS: this forum works very bad on my PC, i'm trying to post this message 3rd attempt...
Best wishes, Denis.
Best wishes, Denis.
- hanmon
- Thank you received: 23
7 years 8 months ago #126386
by hanmon
Replied by hanmon on topic Retrofitting a 1986 Maho MH400E
Hi Dennis,
download the code:
github.com/jin-eld/mh400e-linuxcnc
look at the wiki:
github.com/jin-eld/mh400e-linuxcnc/wiki/...-Component---Testing
it says:
Copy the entire set of downloaded files from github into a folder such as /home/linuxcnc/gearbox_sim
cd .. up to you linuxCNC folder
sudo halcompile --install mh400e_gearbox.comp
But this code is only for the gear change, not for tool change.
You own one of the rare 400T models with a tool changer.
I would love to have one on my machine
Can you upload the schematic of the tool-changer ?
I can upload my latest configs (HAL, INI) tomorrow.
Hanno
download the code:
look at the wiki:
it says:
Hanno
The following user(s) said Thank You: R2AIV
- R2AIV
7 years 8 months ago #126390
by R2AIV
Hi Hanno! I'm talking about tool hold/release circuit, not automatic tool changer. My MH400T doesn't have automatic tool changer. Upload your HAL/ini please, it can be very usefull for me. Thank you!
Best wishes, Denis.
Best wishes, Denis.
- RotarySMP
- Thank you received: 595
7 years 8 months ago #126409
by RotarySMP
On my 400E, the tool is held by springs, and release hydraulically. There is only one Relay. You connect that relay to a HAL pin, and button of your choice. Push the button, hydraulic pump turns on and kicks out the tool. To put in a new tool you push the same button and when you release it, the gripper springs pull in the tool.
Mark
Mark
- R2AIV
7 years 8 months ago #126479
by R2AIV
Hi! Where i can find your hal/ini?
- hanmon
7 years 8 months ago #126484
by hanmon
you can find my current config files in the attachment:
Hanno
Hanno
The following user(s) said Thank You: J Green
Time to create page: 0.196 seconds
