- Thank you received: 595
Retrofitting a 1986 Maho MH400E
- RotarySMP
7 years 5 months ago - 7 years 5 months ago #133537
by RotarySMP
I don't want to waste your retrofit sunday, in case you are waiting for HAL/INI input so here are my current files.
I dont have many tool holders, so I currently down use the tool changer comp. I just break my ngc files into separate tool files, and manually change tools and touch off.
Currently everything is in these three files.
Warning, my Y axis EXE channel died, and the Ebay special 601 EXE I bought is only 0.005mm resolution, so it is only 200 per unit scale. If your three exe's work, this need to be 1000.
Mark
Mark
Last edit: 7 years 5 months ago by RotarySMP.
The following user(s) said Thank You: Glemigobles
- Glemigobles
- Thank you received: 18
7 years 5 months ago #133538
by Glemigobles
Replied by Glemigobles on topic Retrofitting a 1986 Maho MH400E
I hope it works well at 8mm Ap, since it's still going to take 7 passes to complete the pocket. If you're using trochoidal milling you can increase the feed. To avoid chatter, the cutting width should be 2/3 of the tool diameter, and it should never be set exactly at 1/2 D or the endmill will leave a thin strip of material between each pass (since endmills are tolerated at - only and never +, they're never exactly e.g. 16mm but rather a bunch of microns short of their "ideal" diameter). In short, width of cut is best if the resulting toolpaths overlap.
- Glemigobles
7 years 5 months ago #133539
by Glemigobles
If you do plunge milling as suggested, remember you have to first drill (or rather helical mill; I'm still thinking 2,5D toolpaths) a point of entry, since you're not starting from the outside of the material like John does in the NYCCNC video. I also don't know how well that strategy would work with a standard HSS endmill, they can't take the same abuse that carbide bits do.
Thanks a lot for the files, I'm down to connecting the EXE now, then the config begins!
- RotarySMP
7 years 5 months ago - 7 years 5 months ago #133551
by RotarySMP
Looks like 20 year old version of FeatureCAM doesn't offer a plunge milling strategy. Wont cutting 11mm wide x 8mm deep also be a huge bending load?Like killed my 14mm mill?
FeatureCAM is estimating nearly 3 hours of cutting time. Is it realistic to expect a new HSS end mill to last that long, or should break the tool path up and touch it up on the Clarkson it each hour or so?
Mark
Mark
- Glemigobles
7 years 5 months ago #133556
by Glemigobles
Usually, endmills are designed to work 2 hours at their maximum parameters. I'd say at 3 hours you're safe.
- RotarySMP
7 years 5 months ago #133559
by RotarySMP
thanks Im cutting the third level now. your recommended feeds, depth width and and speeds are working well
Time to create page: 0.217 seconds
