- Thank you received: 9
Retrofitting a 1986 Maho MH400E
- aluplastvz
7 years 5 months ago - 7 years 5 months ago #132936
by aluplastvz
Replied by aluplastvz on topic Retrofitting a 1986 Maho MH400E
Last edit: 7 years 5 months ago by aluplastvz.
- RotarySMP
- Thank you received: 595
7 years 5 months ago #132945
by RotarySMP
Hi Glemigobles. Can you understand German? There is a german guy "talla83" who has done a set of very good set of MESA config you tube videos.
www.youtube.com/user/talla83/videos
I know how you feel about the difficulty of collecting necessary info. I must say how cool it was when I saw that PCW had answered your MESA config query with 13 minutes. This is an impressive help desk that is running here. You'll get there.
It is also interesting which parts of these projects sail by with ease, verses the stupid little details which can take considerable energy to overcome. Like I can't get the stupid tool height setter, or the encoders on my panel working, but otherwise got the thing running.
Hi Aulplastv. That is a cool feeling when you bring such a beast under your control. Good one.
Mark
Mark
- Glemigobles
- Thank you received: 18
7 years 5 months ago - 7 years 5 months ago #132956
by Glemigobles
Replied by Glemigobles on topic Retrofitting a 1986 Maho MH400E
Unfortunately, I only understand enough basic German to not get completely lost when I'm abroad, technical language is beyond me. I tried turning on subtitles with automatic translation to English, that went about as well as one could expect
I agree about PCW's quick reply, it's just sad that I don't understand what to do with it
In your instructions, you write about checking pins on cards with the hal command; did you have a configuration file by that point?
What's really my issue at this stage is that I don't quite understand the sequence of what has to be done next. The Mesa cards are connected to power and to each other, I removed the Philips control. Should I now make a config (and if so, do I have to set one up manually if PNCconf doesn't work with the 7i77_7i74 firmware?) and then connect the hardware?
That is to say, does one edit the configuration file when each hardware component is added and test it, starting from a barebones file that doesn't really have anyhting correctly configured? Or should the machine be connected to the Mesa cards first, to help the configuration utility do its job?
EDIT: Attached the error from PNCConf, it pops up after I click to accept the selected firmware (which was installed on the 5i25 and verified).
Last edit: 7 years 5 months ago by Glemigobles.
- RotarySMP
7 years 5 months ago #132960
by RotarySMP
With just the 5i25/7i77/7i84, bought as a LinuxCNC plug npray kit from Mesa, I didn't have to flash any hardware.
So first I set up the pc with the MESA cards and a 24VDC PSU for field power. Once the MESA Cards talked to each other properly, I used PNCConf to set up the basics of the three axis mill, with servos and encoders, and a couple of other options from the PNCCoonf which sounded like I wanted them. I have never used PNCConf since, and I think all the options I added have since been edited or deleted/commented out.
After that it is all manual editing of the HAL and INI files, testing as you go.
My approach was:
1/ encoder feedback. Wiring the encoders into the 7i77, configuration of the INI for the correct sense and increments, pulling apart and cleaning sensor heads, replacing EXEs till they work reliably.
2/ servo interface and tuning. Getting the direction to match the encoders. Tuning using HALScope. Setting up the homing to the encoder reference indexs, setting accel and speeds in INI, etc.
3/ gearbox electrical interface and feedback. Wiring all the feedback switches, manually turning gearbox shafts and checking the switch states with HALSHOW. Wiring the gearbox and spindle motor control relays.
4/ gearbox comp testing. (I got really lucky here that my friend Sergei who is a real programmer stepped up to do this for me. We are aiming for a final improved version this summer, but it works as is.) Recompiling LinuxCNC with the Gearboc comp. Testing the directions (I believe the 500E and 600E have the input gear shaft running reversed to the 400E).
At that point you should have a working machine, using a normal keyboard.
5/ user control panel and interface. You would think that by this time one should be good at HALfui and Ini Karate, but I still seem to have to stop and look up every single little step. I still need to get my feedrate override and jog speed encoders working. Then renet the spindle start buttons once we have the new gearbox comp.
6/ adding accessories. Currently the Tool height setter, and 3D Probe projects. In the future I am sure that a rotary axis project.
Mark
My approach was:
Mark
The following user(s) said Thank You: Glemigobles
- RotarySMP
7 years 5 months ago - 7 years 5 months ago #132962
by RotarySMP
If PNCconf doesn't have a config for the 7i74, just do the basic 5i25 + 7i77 config in PNCConf. Then in the HAL manually edit that one line PCW indicated. Then restart the system with the 7i74 connected, and use HALShow to see if the 7i74 pins are now available to you.
Last edit: 7 years 5 months ago by RotarySMP.
- Glemigobles
7 years 5 months ago #132964
by Glemigobles
Thanks a lot Mark! I edited my previous reply to include the error message from PNCConf.
Going to try your suggestion now.
Time to create page: 2.651 seconds
