Retrofitting a 1986 Maho MH400E
7 years 6 months ago - 7 years 6 months ago #132331 by rodw
Replied by rodw on topic Retrofitting a 1986 Maho MH400E
RotarySMP wrote: That looks really nice. How reliable is the wireless connection?
Mark
Its never let me down and the batteries last forever. The correct part number for a Mesa config is ATWGP01-6BB-3.
That is a 5 volt compatible encoder with coded binary signals for the scale and axis selection switch to save pins. It can control 6 axes so there are a couple of extra MPG outputs. I was thinking of using one for reverse run...
The only thing I've found is that by default the estop is enabled so you need to switch it on or off or hit the estop on startup. I thin that is by design. I use estop_latch to merge the stop chain in HAL.
Last edit: 7 years 6 months ago by rodw.
7 years 6 months ago #132341 by pl7i92
Replied by pl7i92 on topic Retrofitting a 1986 Maho MH400E
the wirerd XHC-hb04 is a great gift at 80USD
it has all buttens free programable in HAL
i use it the way as i cna do MPG 0.01 .02 0.5 steps
and on F6 F7 i can go 200 500 1500 mm/min Jog decision on mpg press for the large plasma tables
no need to rotate like grazy
7 years 6 months ago #132350 by RotarySMP
Doing things the hard way come naturally to me :)
7 years 6 months ago #132352 by RotarySMP
I am also very good at starting projects, and very patient at letting them mature.
I was given a tool holder with a broken off carbide jamming the hole.
Picked up some offcuts of an industrial plastic. (something harder but still insulative would be better)
Scrap endmills provide 6mm carbide shafting. These ones I bought as scrap, although I have a talent for produing scrap end mills.
Six balls from bearing
And a slug of Meehanite.
You can probably guess where this is going.
7 years 6 months ago #132353 by pl7i92
i am pretty shure that there are Holders like you need
from older shops on low cost
most upgrde there stuff regular and sell the old stuff
7 years 6 months ago - 7 years 5 months ago #132356 by RotarySMP
I'll need a cylinderical surface, and took a shot at hard turning the tool holder, but carbide and hard turning --> the carbide loses. I'll grind that round between centers with the Clarkson.
Last edit: 7 years 5 months ago by RotarySMP.
Time to create page: 2.047 seconds
