- Thank you received: 9
Retrofitting a 1986 Maho MH400E
- aluplastvz
7 years 5 months ago #132618
by aluplastvz
Replied by aluplastvz on topic Retrofitting a 1986 Maho MH400E
Thanks to Mark on the answer
This is a problem in the test program
- RotarySMP
- Thank you received: 595
7 years 5 months ago - 7 years 5 months ago #132619
by RotarySMP
Last edit: 7 years 5 months ago by RotarySMP.
- RotarySMP
7 years 5 months ago #132620
by RotarySMP
Glad that helped. Did you pack your EXE's into that die cast Aluminium housing? Why? No space in the control cabinet?
Mark
Mark
- RotarySMP
7 years 5 months ago - 7 years 5 months ago #132656
by RotarySMP
I wired up my tool height setter like this...
Looking at
with HALShow, the pin is high, but it is not reacting to the switch opening. I measure the voltage from TB8-11 to gnd and it remains 24VSC even when the button is pressed. Doing a continuity test on just the switch, it is NC but opens at the button press.
Have I wired this wrong?
Mark
Looking at
hm2-5i25.0.7i77.0.0.input-10
Mark
- RotarySMP
7 years 5 months ago - 7 years 5 months ago #132658
by RotarySMP
- RotarySMP
7 years 5 months ago #132660
by RotarySMP
I rewired it to the first schematic, and tested it, but it still doesn't work. The pin stays high, even when the button is pressed.
Any suggestions appreciated.
Mark
Mark
Time to create page: 1.138 seconds
