Bridgeport Series 2 Interact 4 Retrofit
- bright
3 years 10 months ago - 3 years 10 months ago #259739
by bright
Replied by bright on topic Bridgeport Series 2 Interact 4 Retrofit
Hi, I recently got a few ultra 3000 drivers with servo motors. I've worked with steppers a lot but these servos are new to me, could you possibly send me a wiring diagram of how you hooked them up in your setup?
Last edit: 3 years 10 months ago by bright.
3 years 10 months ago #259900
[code]I couldn't feel any vibration in the motors up to P values of 250 but watching the f error plots I increased the P value until the error just started to oscillate and then backed off 10.[/quote]
The Zeigler Nichols method has you _halve_ the P gain at oscillation, so backing off by 10 might still be a bit close to the edge: eng.libretexts.org/Bookshelves/Industria...egler-Nichols_Method
Replied by andypugh on topic Bridgeport Series 2 Interact 4 Retrofit
The right number is the right number, I have seen P-gains from 0.001 to 100,000 in the day job. It largely depends on the units of what is being controlled (if it's hPa of fuel pressure with a target of 2,000,000 and the output is a 0.00 to 1.00 duty cycle then you will see a very small P, for example)I ended up with P values in the 150 range though, which seemed quite high
Moderators: piasdom
