Bridgeport Series 2 Interact 4 Retrofit
4 years 9 months ago - 4 years 9 months ago #232354 by moosedesign
Replied by moosedesign on topic Bridgeport Series 2 Interact 4 Retrofit
Yes confirmed I have 24V to field and a 5V 2A supply for the 7i92 with jumpers set to pass to the 7i76, both power lights on the 7i76 as well. Going through the 7i92/7i76 config from pncconf I commented out all of the lines that prevented linuxcnc from starting up. Essentially it was all of the 7i76 io pins, can be seen in the attached HAL file. When I had it running I ran HAL show pins and attached the output as well. The only io pin that allowed a startup was hm2_7i92.0.gpio.000.in which I think is a 7i92 pin directly and not addressing the 7i76? As well, the stepgen pins also didn't cause issues but when jogging around with an led attached to the direction pin it is flashing both ways, not on one way and off the other as I would expect.
One error I was not expecting is "unexpected realtime delay on task 0" and "hm2/hm2_7i92.0: error finishing read! iter=6" I have servo_period set to 20,000 with my max jitter over 4 hours measured as 16246. I had to increase the servo period to 500,000 to make these errors on startup go away.
I feel its time to put the 7i76 aside and get the 7i85 working with analogue outputs so I can get some machining work done. Is there an example someone has to address io and analogue pins on a serial connected device to the 7i85? I have a 7i83 and 7i84 connected for io and analogue out.
Cheers,
File Name: bridgeport...1-18.hal
File Size:11 KB
File Name: pins.txt
File Size:57 KB
Last edit: 4 years 9 months ago by moosedesign.
4 years 9 months ago #232356 by PCW
Replied by PCW on topic Bridgeport Series 2 Interact 4 Retrofit
1. The servo period should be 1 ms (1000000)
2. If you are using a 7I76, you must have:
A. Proper firmware with 7I76 support in the 7I92
B. Both 5V and field power supplied to the 7I76
C. The 7I76 connected to the correct 7I92 port
4 years 9 months ago #232360 by moosedesign
Perfect the servo period at 1ms shows no errors at startup! I am getting joint following errors when I jog around but I haven't looked through my joint config carefully yet.
A. I am using the 7i92_7i76x1D.bit file flashed and confirmed with mesaflash
B. 5V is supplied to the 7i92 (2A supply) with W3 and 4 set up. Do I need a separate external supply?
C. I am plugged into 7i92 port P2
4 years 9 months ago #232361 by PCW
You need field power supplied to the 7I76 (8 to 32V on the orange connector)
4 years 9 months ago #232362 by moosedesign
Yes sorry also have 24V supply to the 7i76, field power led is on.
4 years 9 months ago #232364 by PCW
7I76 W1, W2, W3 all in left hand position?
Moderators: piasdom
Time to create page: 0.263 seconds
