Avon 3000 Mill retrofit
16 Dec 2025 05:33 #340171 by zoeper
Replied by zoeper on topic Avon 3000 Mill retrofit
I do like your thinking!
I have been toying with putting an encoder on the spindle. (I have some spindle encoders that was salvaged off Mori-Seiki lathes in a box somewhere) Using the index marker on those should give an accurate rev counter for the MESA and HAL implementation. I would also have a solid encoder for the spindle, should I want to venture into rigid tapping...:thinking
The following user(s) said Thank You: NWE
16 Dec 2025 06:15 - 16 Dec 2025 08:33 #340174 by NWE
Replied by NWE on topic Avon 3000 Mill retrofit
For the record, don't repeat the mistake I made a while back. I mounted the encoder inside the belt drive housing to some shaft driven by gearbelt. If I remember right I used a hal mux switch to select encoder scale according to backgear position. It all worked pretty good, but foiled all attempts at tapping because the encoder was not at a 1:1 ratio to the spindle. I think the big problem was index changed with each spindle revolution.
I figure it would have worked better to drive the encoder at a 1:1 ratio with the actual spindle.
Last edit: 16 Dec 2025 08:33 by NWE.
The following user(s) said Thank You: zoeper
16 Dec 2025 09:26 #340180 by zoeper
Valuable advice NWE, I will keep this in mind going forward.
16 Dec 2025 19:34 #340208 by zoeper
I made some progress today. Hooked up all limit switches and the "E-stop out" output.It functions, but I have trouble measuring the output using a multimeter and I suspect it need to be pulled up (using the 7i77D with sinking outputs.
I did manage to run the Default LinuxCNC logo engraving Gcode without the belts connected, and it was good to see the motors doing their thing at LinuxCNC;s command.
Another observation: If I actuate a limit (+vector or -vector, not the overtravel), the control trips the estop circuit, instead of just holding feed in that direction. is this correct?
I am trying to get as far as possible using PNCConf as HAL is still foreign to me.
Next would be to get the rest of the E-stop (including overtravel) circuit connected and tested before I hook up the belts.
Homing on this machine used to involve looking for the -vector switches (could be +Vector on Z) and reversing direction off the limit until the index marker is found. Can this be set up using PNCConf as well?
17 Dec 2025 01:50 - 17 Dec 2025 02:09 #340222 by NWE
 Good question. I have little to no experience with limit switches in LinuxCNC. Hopefully someone else who knows more about this can enlighten us. As I recall, most machines with oem controllers I've worked on generally e-stop when a limit gets bumped. I did find this:
forum.linuxcnc.org/9-installing-linuxcnc...tch-behavior?start=0
I see on your schematic, the machine has overtravel switches wired direct to the master e-stop. How did the original controller act when you ran into a vector limit? I wonder if those were being used as "soft limits"? LinuxCNC has that in software , can be set right in your Pncconf, the top 3 or 4 values for each axis config page. I expect the best way to handle it would be to enter your axis measurements in Pncconf such that LinuxCNC's soft limit stops the axis reliably a bit short of activating the vector switches. With shared homing it will be ok to bump the vector switch for homing.
Last edit: 17 Dec 2025 02:09 by NWE.
17 Dec 2025 02:02 - 17 Dec 2025 02:18 #340223 by NWE
Decide which end of the limit you want to home to, then pick shared home+limit for the associated switch(es). You will also need to specify Home search direction and home latch direction in each axis page. I know LinuxCNC has homing to index, but I don't currently have that bit figured out on my current retrofit project.
Last edit: 17 Dec 2025 02:18 by NWE.
17 Dec 2025 05:27 #340228 by zoeper
I missed the "shared home and limit" option.
Thank you for pointing that out!
Moderators: piasdom
Time to create page: 0.216 seconds
