Retrofitting Deckel FP4ATC
- Mbrand1901
- Thank you received: 4
02 Jan 2026 17:57 - 02 Jan 2026 19:04 #340894
by Mbrand1901
Retrofitting Deckel FP4ATC was created by Mbrand1901
Last edit: 02 Jan 2026 19:04 by Mbrand1901.
- Mbrand1901
02 Jan 2026 19:51 - 02 Jan 2026 19:57 #340897
by Mbrand1901
Replied by Mbrand1901 on topic Retrofitting Deckel FP4ATC
This machine has a Contour 3 controller.
At first i want to move all axis. Then the spindle and at last the toolchanger.
I want to keep the old simens servos with the bosch servocontrolls. I also want to keep the linear Heidenhein encorder. They are still in a good shape and still work.
A list of all the components on the machine i want to keep to move the table:
Heidenhein LS904
Bosch tr15-xa-140-230V
Simens 1HU3071-0AC01-Z
Heidenhein LS904
Last edit: 02 Jan 2026 19:57 by Mbrand1901.
- Mbrand1901
02 Jan 2026 20:26 #340898
by Mbrand1901
The original contoller (in the control cabinet) has 56 Inputs and 92 Outputs.
I am going to ned an analog Output for the servos and a sin/cos (1 Vpp)u Input for the linear encoders. The servos also have some encoders on them, but these are only for the velocity.
Later i am going to need another analog Output for the spindle.
In my mind i am going to use a mesa 7i80HDT as a base for the daugthercards. For the spindle and the servos a 7i77 and for the linear encoders a 7i85, because that one can read the 1 Vss signal.
For the other I/Os i would use some 7i70‘s and 7i71‘s.
Please correct me, if i am going to make a mistake?
- Thank you received: 7485
02 Jan 2026 21:50 #340899
Replied by tommylight on topic Retrofitting Deckel FP4ATC
No, Mesa 7i80 does not go with 7i77 and 7i85, the Mesa 7i92TM goes with those. 7i80 is 50 pin, 7i92 is 25/26pin.
There are other options also, the 7i77 is hard to find so a bit more searching is needed, on the 50 pin stuff i can not help, but for 25 pin stuff i used a lot, here are some options:
-7i97T it is roughly the same as 7i92TM with 7i77, with 7i85 or even better with 7i74 as this needs plain LAN cables to wire the 7i70 (48 inputs) and/or 7i71/7i72 (48 outputs sinking or sourcing), or 7i84 (32 in and 16 out)
-7i92TM (notice the M, makes it directly plugable into 7i77 so no need for IDC26 to DB25 cable and adapter), with 7i85 OR 7i74
-7i96S (step/dir and spindle) with 7i83 (analog outputs) and 7i85 (encoder and SSerial) for 7i70/7i71/7i72/7i84
I think there is also 7i93 IRC should have 3 of IDC26 headers, but not sure, should be same as 7i92 with more IO. Again, do double check this.
- Mbrand1901
03 Jan 2026 10:16 #340909
by Mbrand1901
Thank you for your help. I will look in to the availability of these cards and then i am going to decide. But the 7i97T looks promising.
Next week i will recive the electrical manual and then I can determin the exact number of I/Os and wich signal they need.
- Mbrand1901
05 Jan 2026 16:55 #341013
by Mbrand1901
Hello again!
I finally received the drawings of the electrical, hydraulic and air circuits. Now I will count the exact number of I/Os. Then I will make a list with the exact signal of each I and O needs. It would be nice, if someone could correct me on my choice of mesa cards.
Here they are (lower resolution), maybe I can help someone with this:
- Hartwig
05 Jan 2026 17:58 #341015
by Hartwig
Replied by Hartwig on topic Retrofitting Deckel FP4ATC
Hi Mbrandt,
I am using the Mesa 7i97T for 4 seperate axes with Heidenhain encoders and Tacho DC servo motors on my milling machine.
My servo amplifiers get the setpoint +- 10V and the Enable signal from the Mesa card. Very simple and straightforward. The inputs from the Heidenhain EXE ( I would assume, that your machine has the Heidenhain EXE card/units on board) are also easy to connect. The read-out of the positions worked immediately.
I bought the MESA card from EUSurplus in Portugal - the only source, where it was available in Europe, Highly recommended dealer.
Best regards
Hartwig
Best regards
Hartwig
- Mbrand1901
06 Jan 2026 06:05 #341046
by Mbrand1901
Hello Hartwig,
Thank you for your reply. I think my machine has some sort of EXE, its a board and the name is NCP59. But i dont know where to intercept the TTL signal from it. There is a version of this board with an extra digital output, but i dont have it on my machine. And buying 3 Heidenhein EXE is a step back. I would like to use a modern version of that. Maybe a 7i85S or someting like that?
And the Suplier you sent seams good and I will buy der 7i97T from him.
Here is a picture of the NCP 59:
(1, 2, 3 are X, Y, Z)
- Hartwig
06 Jan 2026 09:29 - 29 May 2026 19:40 #341050
by Hartwig
Hello Mbrandt.
I have used the following type of "HDH Exe Platine" with 3 channels.
www.ebay.de/itm/204779209363?srsltid=Afm...Gj67v4RUzT0PLvOgckrB
Very simple and very small. It fits between the glas scales and to the MESA directly. For mine I have paid less than 200 Euro.
Last edit: 29 May 2026 19:40 by Aciera. Reason: Remove failed upload, see image in the post below
- Hartwig
06 Jan 2026 09:36 #341051
by Hartwig
Sorry for the previous message. I hope, this works.
Best regards
Hartwig
Best regards
Hartwig
Moderators: piasdom
Time to create page: 0.297 seconds
