Retrofitting Deckel FP4ATC
- Thank you received: 5325
12 Mar 2026 17:57 #344184
Replied by PCW on topic Retrofitting Deckel FP4ATC
7i97t_7i74d.bin would be the correct firmware for a 7I97T +7I74
Note that with this firmware sserial channel 0 is on the 7I97T
and channels 1..7 are on the 7I74 (7I74 physical channel 0 does not work)
- Mbrand1901
- Thank you received: 4
12 Mar 2026 20:15 #344193
by Mbrand1901
Replied by Mbrand1901 on topic Retrofitting Deckel FP4ATC
I have only used firmwares from the Website. I also know that i only need a 7i97t with 7i74 firmeware. In the file there are a few firmwares with the 7i97t_7i74 Name. So the 7i97t_7i74d.bin is the right now?
Tomorow i will look further in to it.
And why the encoders arent counting.
12 Mar 2026 21:08 - 12 Mar 2026 21:19 #344194
Just checked 7i97t_7i74d.bin
md5sum=
4130ebee623115267327c166f8da9d39 7i97t_7i74d.bin
All encoders work, 7I97 sserial (0) and all 7I74 sserial channels (1..7) work as expected
md5sum=
Last edit: 12 Mar 2026 21:19 by PCW.
The following user(s) said Thank You: RotarySMP, tommylight
Moderators: piasdom
