× Forum Header
keep getting an error message, first time user
31 Dec 2011 16:39 #16156 by deanno
Been trying to set my drivers and motors using the stepcon fig wizard. But when i try to move the axis on the jog page , All i get are error messages, the first one i got was-
"Stepconf encountered an error. The following information may be useful in troubleshooting:
File "/usr/bin/stepconf", line 1911, in on_jogplus_pressed
self.update_axis_params()
File "/usr/bin/stepconf", line 1900, in update_axis_params
halrun.flush()
IOError: [Errno 32] Broken pipe"
So followed some previous advice and used the terminal and then got the following
/usr/bin/stepconf:24: DeprecationWarning: the md5 module is deprecated; use hashlib instead
import md5
/usr/bin/stepconf:1142: Warning: g_path_get_dirname: assertion `file_name != NULL' failed
self.xml = gtk.glade.xml_new_from_buffer(doc, len(doc), domain="axis")
/usr/bin/stepconf:1142: GtkWarning: gdk_pixbuf_new_from_file: assertion `filename != NULL' failed
/usr/bin/stepconf:1142: Warning: g_object_unref: assertion `G_IS_OBJECT (object)' failed
/usr/bin/stepconf:1142: GtkWarning: GtkSpinButton: setting an adjustment with non-zero page size is deprecated
/usr/bin/stepconf:2100: GtkWarning: GtkSpinButton: setting an adjustment with non-zero page size is deprecated
widgets.testvel.set_range(0, maxvel)
/usr/bin/stepconf:2101: GtkWarning: GtkSpinButton: setting an adjustment with non-zero page size is deprecated
widgets.testacc.set_range(1, 100000)
/usr/bin/stepconf:2102: GtkWarning: GtkSpinButton: setting an adjustment with non-zero page size is deprecated
widgets.testamplitude.set_range(0, 1000)
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 Operation not permitted
RTAPI: ERROR: could not open shared memory (errno=2)
HAL: ERROR: rtapi init failed
halcmd: hal_init() failed: -22
NOTE: 'rtapi' kernel module must be loaded
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
ERROR: Module rtai_sched does not exist in /proc/modules
ERROR: Module rtai_hal does not exist in /proc/modules
I did try all axis in case one would work but nothing
31 Dec 2011 16:49 #16157 by PCW
looks like realtime did not load, can you post the output of dmesg?
31 Dec 2011 16:58 #16158 by deanno
Sorry, not sure what you mean by dmesg
31 Dec 2011 18:56 - 31 Dec 2011 19:06 #16160 by PCW
type
dmesg > somefilename
in a terminal window
(control alt T to pop up a terminal window)
and post somefilename here
(after attempting to start EMC)
Last edit: 31 Dec 2011 19:06 by PCW. Reason: ommision
31 Dec 2011 19:01 #16161 by BigJohnT
Here is a couple of pages on Linux Tips.
linuxcnc.org/docview/html/common_Linux_FAQ.html
31 Dec 2011 19:13 - 31 Dec 2011 19:31 #16163 by deanno
I tried the wizard up to jogging the motors, then done the dmesg. Hope that was the right way
[ 0.008533] ... fixed-purpose events: 0
[ 0.008536] ... event mask: 000000000000000f
[ 0.008544] Checking 'hlt' instruction... OK.
[ 0.024951] SMP alternatives: switching to UP code
[ 0.033895] Freeing SMP alternatives: 31k freed
[ 0.033963] ACPI: Core revision 20090903
[ 0.037572] ACPI Warning: Detected an unsupported executable opcode at module-level: [0x007B] at table offset 0x0094 (20090903/psloop-522)
[ 0.037588] ACPI Warning: Detected an unsupported executable opcode at module-level: [0x007B] at table offset 0x0099 (20090903/psloop-522)
[ 0.040517] ACPI: setting ELCR to 0008 (from 1c28)
[ 0.041720] ftrace: converting mcount calls to 0f 1f 44 00 00
[ 0.041738] ftrace: allocating 21003 entries in 42 pages
[ 0.051437] Enabling APIC mode: Flat. Using 0 I/O APICs
[ 0.051448] weird, boot CPU (#0) not listed by the BIOS.
[ 0.051451] SMP motherboard not detected.
[ 0.051457] Local APIC not detected. Using dummy APIC emulation.
[ 0.051460] SMP disabled
[ 0.052123] Brought up 1 CPUs
[ 0.052128] Total of 1 processors activated (2932.80 BogoMIPS).
[ 0.052736] CPU0 attaching NULL sched-domain.
[ 0.053105] devtmpfs: initialized
[ 0.053649] regulator: core version 0.5
[ 0.053745] NET: Registered protocol family 16
[ 0.053968] EISA bus registered
[ 0.053984] ACPI: bus type pci registered
[ 0.085295] PCI: PCI BIOS revision 2.10 entry at 0xfb250, last bus=1
[ 0.085299] PCI: Using configuration type 1 for base access
[ 0.086517] bio: create slab <bio-0> at 0
[ 0.087146] ACPI: EC: Look up EC in DSDT
[ 0.092183] ACPI: Interpreter enabled
[ 0.092187] ACPI: (supports S0 S5)
[ 0.092206] ACPI: Using PIC for interrupt routing
[ 0.096354] ACPI: No dock devices found.
[ 0.096511] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.096583] pci 0000:00:00.0: reg 10 32bit mmio pref: [0xd0000000-0xd3ffffff]
[ 0.096614] pci 0000:00:00.0: Disabling VIA memory write queue (PCI ID 3112, rev 00): [55] f9 & 1f -> 19
[ 0.096675] pci 0000:00:01.0: supports D1
[ 0.096781] pci 0000:00:07.1: reg 20 io port: [0xc000-0xc00f]
[ 0.096844] pci 0000:00:07.2: reg 20 io port: [0xc400-0xc41f]
[ 0.096904] pci 0000:00:07.3: reg 20 io port: [0xc800-0xc81f]
[ 0.096982] pci 0000:00:07.4: quirk: region 6000-607f claimed by vt82c686 HW-mon
[ 0.096988] pci 0000:00:07.4: quirk: region 5000-500f claimed by vt82c686 SMB
[ 0.097033] pci 0000:00:07.5: reg 10 io port: [0xcc00-0xccff]
[ 0.097041] pci 0000:00:07.5: reg 14 io port: [0xd000-0xd003]
[ 0.097049] pci 0000:00:07.5: reg 18 io port: [0xd400-0xd403]
[ 0.097119] pci 0000:00:08.0: reg 20 io port: [0xdc00-0xdc1f]
[ 0.097179] pci 0000:00:08.1: reg 20 io port: [0xe000-0xe01f]
[ 0.097226] pci 0000:00:08.2: reg 10 32bit mmio: [0xdd080000-0xdd0800ff]
[ 0.097263] pci 0000:00:08.2: PME# supported from D0 D3hot
[ 0.097268] pci 0000:00:08.2: PME# disabled
[ 0.097303] pci 0000:00:09.0: reg 10 io port: [0xe400-0xe4ff]
[ 0.097310] pci 0000:00:09.0: reg 14 32bit mmio: [0xdd081000-0xdd0810ff]
[ 0.097332] pci 0000:00:09.0: reg 30 32bit mmio pref: [0x000000-0x00ffff]
[ 0.097349] pci 0000:00:09.0: supports D1 D2
[ 0.097352] pci 0000:00:09.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.097357] pci 0000:00:09.0: PME# disabled
[ 0.097385] pci 0000:00:0a.0: reg 10 32bit mmio: [0xd9000000-0xd9ffffff]
[ 0.097393] pci 0000:00:0a.0: reg 14 32bit mmio pref: [0xd4000000-0xd7ffffff]
[ 0.097401] pci 0000:00:0a.0: reg 18 32bit mmio pref: [0xdd000000-0xdd07ffff]
[ 0.097417] pci 0000:00:0a.0: reg 30 32bit mmio pref: [0x000000-0x01ffff]
[ 0.097488] pci 0000:01:00.0: reg 10 32bit mmio: [0xdb800000-0xdbffffff]
[ 0.097496] pci 0000:01:00.0: reg 14 32bit mmio: [0xdc000000-0xdc01ffff]
[ 0.097504] pci 0000:01:00.0: reg 18 32bit mmio: [0xdb000000-0xdb7fffff]
[ 0.097520] pci 0000:01:00.0: reg 30 32bit mmio pref: [0x000000-0x00ffff]
[ 0.097540] pci 0000:01:00.0: supports D1 D2
[ 0.097577] pci 0000:00:01.0: bridge 32bit mmio: [0xda000000-0xdcffffff]
[ 0.097587] pci_bus 0000:00: on NUMA node 0
[ 0.097595] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.119002] ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 5 6 7 10 11 *12 14 15)
[ 0.119243] ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 5 6 7 10 *11 12 14 15)
[ 0.119487] ACPI: PCI Interrupt Link [LNKC] (IRQs 1 3 4 5 6 7 *10 11 12 14 15)
[ 0.119729] ACPI: PCI Interrupt Link [LNKD] (IRQs 1 3 4 *5 6 7 10 11 12 14 15)
[ 0.119939] vgaarb: device added: PCI:0000:00:0a.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.119947] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=none,locks=none
[ 0.119952] vgaarb: loaded
[ 0.120230] SCSI subsystem initialized
[ 0.120439] libata version 3.00 loaded.
[ 0.120602] usbcore: registered new interface driver usbfs
[ 0.120623] usbcore: registered new interface driver hub
[ 0.120680] usbcore: registered new device driver usb
[ 0.120923] ACPI: WMI: Mapper loaded
[ 0.120928] PCI: Using ACPI for IRQ routing
[ 0.121167] NetLabel: Initializing
[ 0.121170] NetLabel: domain hash size = 128
[ 0.121173] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.121201] NetLabel: unlabeled traffic allowed by default
[ 0.121271] Switching to clocksource tsc
[ 0.124001] AppArmor: AppArmor Filesystem Enabled
[ 0.124001] pnp: PnP ACPI init
[ 0.124046] ACPI: bus type pnp registered
[ 0.127361] pnp: PnP ACPI: found 11 devices
[ 0.127365] ACPI: ACPI bus type pnp unregistered
[ 0.127373] PnPBIOS: Disabled by ACPI PNP
[ 0.127396] system 00:00: iomem range 0xcf800-0xcffff has been reserved
[ 0.127402] system 00:00: iomem range 0xf0000-0xf7fff could not be reserved
[ 0.127407] system 00:00: iomem range 0xf8000-0xfbfff could not be reserved
[ 0.127412] system 00:00: iomem range 0xfc000-0xfffff could not be reserved
[ 0.127418] system 00:00: iomem range 0x1f7f0000-0x1f7fffff could not be reserved
[ 0.127423] system 00:00: iomem range 0xffff0000-0xffffffff has been reserved
[ 0.127428] system 00:00: iomem range 0x0-0x9ffff could not be reserved
[ 0.127433] system 00:00: iomem range 0x100000-0x1f7effff could not be reserved
[ 0.127438] system 00:00: iomem range 0xfec00000-0xfec00fff has been reserved
[ 0.127443] system 00:00: iomem range 0xfee00000-0xfee00fff has been reserved
[ 0.127455] system 00:02: ioport range 0x4d0-0x4d1 has been reserved
[ 0.162331] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.162336] pci 0000:00:01.0: IO window: disabled
[ 0.162343] pci 0000:00:01.0: MEM window: 0xda000000-0xdcffffff
[ 0.162349] pci 0000:00:01.0: PREFETCH window: 0x20000000-0x200fffff
[ 0.162371] pci 0000:00:01.0: setting latency timer to 64
[ 0.162380] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.162384] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.162389] pci_bus 0000:01: resource 1 mem: [0xda000000-0xdcffffff]
[ 0.162394] pci_bus 0000:01: resource 2 pref mem [0x20000000-0x200fffff]
[ 0.162469] NET: Registered protocol family 2
[ 0.162665] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.163129] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.163461] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.163799] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.163804] TCP reno registered
[ 0.164001] NET: Registered protocol family 1
[ 0.164045] pci 0000:00:00.0: Applying VIA southbridge workaround
[ 0.164053] pci 0000:00:01.0: disabling DAC on VIA PCI bridge
[ 0.164061] pci 0000:00:07.0: Disabling VIA external APIC routing
[ 0.164176] pci 0000:00:0a.0: Boot video device
[ 0.164729] Scanning for low memory corruption every 60 seconds
[ 0.164962] audit: initializing netlink socket (disabled)
[ 0.164988] type=2000 audit(1325359581.162:1): initialized
[ 0.176553] Trying to unpack rootfs image as initramfs...
[ 0.191276] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.193994] VFS: Disk quotas dquot_6.5.2
[ 0.194123] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.199088] fuse init (API version 7.13)
[ 0.199365] msgmni has been set to 952
[ 0.199920] alg: No test for stdrng (krng)
[ 0.199991] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.199998] io scheduler noop registered
[ 0.200002] io scheduler anticipatory registered
[ 0.200005] io scheduler deadline registered
[ 0.200067] io scheduler cfq registered (default)
[ 0.200266] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.200304] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.200450] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.200460] ACPI: Power Button [PWRB]
[ 0.200542] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
[ 0.200554] ACPI: Sleep Button [SLPB]
[ 0.200651] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.200655] ACPI: Power Button [PWRF]
[ 0.207392] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.207575] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.208117] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.209918] brd: module loaded
[ 0.210788] isapnp: Scanning for PnP cards...
[ 0.218898] loop: module loaded
[ 0.219169] input: Macintosh mouse button emulation as /devices/virtual/input/input3
[ 0.220197] Fixed MDIO Bus: probed
[ 0.220259] PPP generic driver version 2.4.2
[ 0.220328] tun: Universal TUN/TAP device driver, 1.6
[ 0.220332] tun: (C) 1999-2004 Max Krasnyansky <This email address is being protected from spambots. You need JavaScript enabled to view it.>
[ 0.220484] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.221178] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 10
[ 0.221184] PCI: setting IRQ 10 as level-triggered
[ 0.221194] ehci_hcd 0000:00:08.2: PCI INT C -> Link[LNKC] -> GSI 10 (level, low) -> IRQ 10
[ 0.221239] ehci_hcd 0000:00:08.2: EHCI Host Controller
[ 0.221309] ehci_hcd 0000:00:08.2: new USB bus registered, assigned bus number 1
[ 0.221397] ehci_hcd 0000:00:08.2: irq 10, io mem 0xdd080000
[ 0.270337] ehci_hcd 0000:00:08.2: USB 2.0 started, EHCI 0.95
[ 0.270708] usb usb1: configuration #1 chosen from 1 choice
[ 0.270767] hub 1-0:1.0: USB hub found
[ 0.270797] hub 1-0:1.0: 4 ports detected
[ 0.270904] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.270940] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.271676] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 5
[ 0.271682] PCI: setting IRQ 5 as level-triggered
[ 0.271691] uhci_hcd 0000:00:07.2: PCI INT D -> Link[LNKD] -> GSI 5 (level, low) -> IRQ 5
[ 0.271708] uhci_hcd 0000:00:07.2: UHCI Host Controller
[ 0.271821] uhci_hcd 0000:00:07.2: new USB bus registered, assigned bus number 2
[ 0.271864] uhci_hcd 0000:00:07.2: irq 5, io base 0x0000c400
[ 0.272043] usb usb2: configuration #1 chosen from 1 choice
[ 0.272087] hub 2-0:1.0: USB hub found
[ 0.272107] hub 2-0:1.0: 2 ports detected
[ 0.272175] uhci_hcd 0000:00:07.3: PCI INT D -> Link[LNKD] -> GSI 5 (level, low) -> IRQ 5
[ 0.272186] uhci_hcd 0000:00:07.3: UHCI Host Controller
[ 0.272250] uhci_hcd 0000:00:07.3: new USB bus registered, assigned bus number 3
[ 0.272274] uhci_hcd 0000:00:07.3: irq 5, io base 0x0000c800
[ 0.272441] usb usb3: configuration #1 chosen from 1 choice
[ 0.272481] hub 3-0:1.0: USB hub found
[ 0.272499] hub 3-0:1.0: 2 ports detected
[ 0.273160] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 12
[ 0.273165] PCI: setting IRQ 12 as level-triggered
[ 0.273173] uhci_hcd 0000:00:08.0: PCI INT A -> Link[LNKA] -> GSI 12 (level, low) -> IRQ 12
[ 0.273182] uhci_hcd 0000:00:08.0: UHCI Host Controller
[ 0.273245] uhci_hcd 0000:00:08.0: new USB bus registered, assigned bus number 4
[ 0.273274] uhci_hcd 0000:00:08.0: irq 12, io base 0x0000dc00
[ 0.273438] usb usb4: configuration #1 chosen from 1 choice
[ 0.273479] hub 4-0:1.0: USB hub found
[ 0.273498] hub 4-0:1.0: 2 ports detected
[ 0.274096] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 11
[ 0.274100] PCI: setting IRQ 11 as level-triggered
[ 0.274109] uhci_hcd 0000:00:08.1: PCI INT B -> Link[LNKB] -> GSI 11 (level, low) -> IRQ 11
[ 0.274117] uhci_hcd 0000:00:08.1: UHCI Host Controller
[ 0.274196] uhci_hcd 0000:00:08.1: new USB bus registered, assigned bus number 5
[ 0.274223] uhci_hcd 0000:00:08.1: irq 11, io base 0x0000e000
[ 0.274394] usb usb5: configuration #1 chosen from 1 choice
[ 0.274436] hub 5-0:1.0: USB hub found
[ 0.274456] hub 5-0:1.0: 2 ports detected
[ 0.274621] PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 0.274626] PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 0.279302] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.279620] mice: PS/2 mouse device common for all mice
[ 0.279975] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 0.280007] rtc0: alarms up to one year, y3k, 242 bytes nvram
[ 0.280220] device-mapper: uevent: version 1.0.3
[ 0.280475] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: This email address is being protected from spambots. You need JavaScript enabled to view it.
[ 0.282746] device-mapper: multipath: version 1.1.0 loaded
[ 0.282757] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.283221] EISA: Probing bus 0 at eisa.0
[ 0.283249] Cannot allocate resource for EISA slot 4
[ 0.283253] Cannot allocate resource for EISA slot 5
[ 0.283256] Cannot allocate resource for EISA slot 6
[ 0.283269] EISA: Detected 0 cards.
[ 0.283276] cpuidle: using governor ladder
[ 0.283280] cpuidle: using governor menu
[ 0.283983] TCP cubic registered
[ 0.284238] NET: Registered protocol family 10
[ 0.284905] lo: Disabled Privacy Extensions
[ 0.285366] NET: Registered protocol family 17
[ 0.285436] Using IPI No-Shortcut mode
[ 0.285652] registered taskstats version 1
[ 0.286044] rtc_cmos 00:04: setting system clock to 2011-12-31 19:26:21 UTC (1325359581)
[ 0.286051] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.286054] EDD information not available.
[ 0.307015] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 0.886579] isapnp: No Plug & Play device found
[ 0.886651] usb 5-1: new low speed USB device using uhci_hcd and address 2
[ 1.062894] usb 5-1: configuration #1 chosen from 1 choice
[ 1.140269] Freeing initrd memory: 13119k freed
[ 1.189982] Freeing unused kernel memory: 620k freed
[ 1.192194] Write protecting the kernel text: 4540k
[ 1.192231] Write protecting the kernel read-only data: 1668k
[ 1.242996] udev: starting version 151
[ 1.577104] pata_via 0000:00:07.1: version 0.3.4
[ 1.591353] scsi0 : pata_via
[ 1.595711] scsi1 : pata_via
[ 1.595858] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xc000 irq 14
[ 1.595864] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xc008 irq 15
[ 1.611208] Floppy drive(s): fd0 is 1.2M
[ 1.612386] Linux agpgart interface v0.103
[ 1.627914] FDC 0 is a post-1991 82077
[ 1.796554] ata1.00: ATA-7: MAXTOR STM380215A, 3.AAD, max UDMA/100
[ 1.796562] ata1.00: 156301488 sectors, multi 0: LBA48
[ 1.796596] ata1.00: limited to UDMA/33 due to 40-wire cable
[ 1.871404] ata1.00: configured for UDMA/33
[ 1.871666] scsi 0:0:0:0: Direct-Access ATA MAXTOR STM380215 3.AA PQ: 0 ANSI: 5
[ 1.872051] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.872765] sd 0:0:0:0: [sda] 156301488 512-byte logical blocks: (80.0 GB/74.5 GiB)
[ 1.872862] sd 0:0:0:0: [sda] Write Protect is off
[ 1.872868] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.872916] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.873214] sda: sda1 sda2
[ 1.920478] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.036384] ata2.00: ATAPI: LITE-ON LTR-32123S, XS0Z, max UDMA/33
[ 2.052390] ata2.00: configured for UDMA/33
[ 2.065653] scsi 1:0:0:0: CD-ROM LITE-ON LTR-32123S XS0Z PQ: 0 ANSI: 5
[ 2.114038] sr0: scsi3-mmc drive: 252x/40x writer cd/rw xa/form2 cdda tray
[ 2.114049] Uniform CD-ROM driver Revision: 3.20
[ 2.114323] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 2.114470] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 2.163539] vga16fb: initializing
[ 2.163554] vga16fb: mapped to 0xc00a0000
[ 2.163866] fb0: VGA16 VGA frame buffer device
[ 2.164384] via-rhine.c:v1.10-LK1.4.3 2007-03-06 Written by Donald Becker
[ 2.164394] via-rhine: Broken BIOS detected, avoid_D3 enabled.
[ 2.164470] via-rhine 0000:00:09.0: PCI INT A -> Link[LNKB] -> GSI 11 (level, low) -> IRQ 11
[ 2.184214] eth0: VIA Rhine III at 0xdd081000, 00:15:e9:b8:13:75, IRQ 11.
[ 2.184931] eth0: MII PHY found at address 1, status 0x7849 advertising 05e1 Link 0000.
[ 2.197119] [drm] Initialized drm 1.1.0 20060810
[ 2.204801] agpgart: Detected VIA KLE133 chipset
[ 2.222998] usbcore: registered new interface driver hiddev
[ 2.224903] agpgart-via 0000:00:00.0: AGP aperture is 64M @ 0xd0000000
[ 2.237277] input: Genius NetScroll + Traveler as /devices/pci0000:00/0000:00:08.1/usb5/5-1/5-1:1.0/input/input5
[ 2.237498] generic-usb 0003:0458:002E.0001: input,hidraw0: USB HID v1.10 Mouse [Genius NetScroll + Traveler] on usb-0000:00:08.1-1/input0
[ 2.237566] usbcore: registered new interface driver usbhid
[ 2.237572] usbhid: v2.6:USB HID core driver
[ 2.390493] nouveau 0000:00:0a.0: PCI INT A -> Link[LNKC] -> GSI 10 (level, low) -> IRQ 10
[ 2.405061] [drm] nouveau 0000:00:0a.0: Detected an NV10 generation card (0x017200a5)
[ 2.405317] [drm] nouveau 0000:00:0a.0: Attempting to load BIOS image from PROM
[ 2.634174] [drm] nouveau 0000:00:0a.0: ... appears to be valid
[ 2.634488] [drm] nouveau 0000:00:0a.0: BMP BIOS found
[ 2.634493] [drm] nouveau 0000:00:0a.0: BMP version 5.21
[ 2.634498] [drm] nouveau 0000:00:0a.0: Bios version 04.17.00.57
[ 2.634505] [drm] nouveau 0000:00:0a.0: Found Display Configuration Block version 2.0
[ 2.634513] [drm] nouveau 0000:00:0a.0: Raw DCB entry 0: 01000100 000088b8
[ 2.634520] [drm] nouveau 0000:00:0a.0: Raw DCB entry 1: 01010302 000088b0
[ 2.634524] [drm] nouveau 0000:00:0a.0: Raw DCB entry 2: 02020321 00000033
[ 2.634803] [drm] nouveau 0000:00:0a.0: Loading NV17 power sequencing microcode
[ 2.634809] [drm] nouveau 0000:00:0a.0: Parsing VBIOS init table 0 at offset 0xCF48
[ 2.634861] [drm] nouveau 0000:00:0a.0: Parsing VBIOS init table 1 at offset 0xD2C2
[ 2.697911] Console: switching to colour frame buffer device 80x30
[ 2.756039] [drm] nouveau 0000:00:0a.0: Parsing VBIOS init table 2 at offset 0xD063
[ 2.776048] [drm] nouveau 0000:00:0a.0: Parsing VBIOS init table 3 at offset 0xD851
[ 2.776066] [drm] nouveau 0000:00:0a.0: Parsing VBIOS init table 4 at offset 0xD21E
[ 2.858056] [TTM] Zone kernel: Available graphics memory: 250654 kiB.
[ 2.858089] [drm] nouveau 0000:00:0a.0: 64 MiB VRAM
[ 2.862161] [drm] nouveau 0000:00:0a.0: 64 MiB GART (aperture)
[ 2.862538] [drm] nouveau 0000:00:0a.0: Allocating FIFO number 0
[ 2.862988] [drm] nouveau 0000:00:0a.0: nouveau_channel_alloc: initialised FIFO 0
[ 2.863002] [drm] nouveau 0000:00:0a.0: Initial CRTC_OWNER is 0
[ 2.863110] [drm] nouveau 0000:00:0a.0: Detected a DVI-I connector
[ 2.863505] [drm] nouveau 0000:00:0a.0: Detected a TV connector
[ 2.865055] [drm] nouveau 0000:00:0a.0: Setting dpms mode 3 on vga encoder (output 0)
[ 2.865062] [drm] nouveau 0000:00:0a.0: Setting dpms mode 3 on tmds encoder (output 1)
[ 2.865069] [drm] nouveau 0000:00:0a.0: Setting dpms mode 3 on TV encoder (output 2)
[ 3.016287] [drm] nouveau 0000:00:0a.0: allocated 1024x768 fb: 0x49000, bo d77e9000
[ 3.016643] fb1: nouveaufb frame buffer device
[ 3.016647] registered panic notifier
[ 3.016659] [drm] Initialized nouveau 0.0.15 20090420 for 0000:00:0a.0 on minor 0
[ 3.234097] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6
[ 3.234103] ata1.00: BMDMA stat 0x24
[ 3.234111] ata1.00: failed command: READ DMA
[ 3.234122] ata1.00: cmd c8/00:01:5f:52:65/00:00:00:00:00/e2 tag 0 dma 512 in
[ 3.234125] res 51/84:00:00:00:00/00:00:00:00:00/e0 Emask 0x10 (ATA bus error)
[ 3.234130] ata1.00: status: { DRDY ERR }
[ 3.234134] ata1.00: error: { ICRC ABRT }
[ 3.234182] ata1: soft resetting link
[ 3.501050] ata1.00: configured for UDMA/33
[ 3.501073] ata1: EH complete
[ 3.965725] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6
[ 3.965730] ata1.00: BMDMA stat 0x24
[ 3.965735] ata1.00: failed command: READ DMA
[ 3.965745] ata1.00: cmd c8/00:01:5f:52:65/00:00:00:00:00/e2 tag 0 dma 512 in
[ 3.965748] res 51/84:00:00:00:00/00:00:00:00:00/e0 Emask 0x10 (ATA bus error)
[ 3.965752] ata1.00: status: { DRDY ERR }
[ 3.965756] ata1.00: error: { ICRC ABRT }
[ 3.965791] ata1: soft resetting link
[ 4.241038] ata1.00: configured for UDMA/33
[ 4.241053] ata1: EH complete
[ 4.705713] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6
[ 4.705718] ata1.00: BMDMA stat 0x24
[ 4.705722] ata1.00: failed command: READ DMA
[ 4.705732] ata1.00: cmd c8/00:01:5f:52:65/00:00:00:00:00/e2 tag 0 dma 512 in
[ 4.705735] res 51/84:00:00:00:00/00:00:00:00:00/e0 Emask 0x10 (ATA bus error)
[ 4.705739] ata1.00: status: { DRDY ERR }
[ 4.705743] ata1.00: error: { ICRC ABRT }
[ 4.705775] ata1: soft resetting link
[ 4.981027] ata1.00: configured for UDMA/33
[ 4.981040] ata1: EH complete
[ 5.445739] ata1.00: limiting speed to UDMA/25:PIO4
[ 5.445750] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6
[ 5.445754] ata1.00: BMDMA stat 0x24
[ 5.445762] ata1.00: failed command: READ DMA
[ 5.445772] ata1.00: cmd c8/00:01:5f:52:65/00:00:00:00:00/e2 tag 0 dma 512 in
[ 5.445775] res 51/84:00:00:00:00/00:00:00:00:00/e0 Emask 0x10 (ATA bus error)
[ 5.445779] ata1.00: status: { DRDY ERR }
[ 5.445783] ata1.00: error: { ICRC ABRT }
[ 5.445831] ata1: soft resetting link
[ 5.712700] ata1.00: configured for UDMA/25
[ 5.712730] ata1: EH complete
[ 6.380160] xor: automatically using best checksumming function: pIII_sse
[ 6.400023] pIII_sse : 4147.000 MB/sec
[ 6.400027] xor: using function: pIII_sse (4147.000 MB/sec)
[ 6.432783] device-mapper: dm-raid45: initialized v0.2594b
[ 7.039823] EXT4-fs (loop0): mounted filesystem with ordered data mode
[ 19.159194] udev: starting version 151
[ 19.639808] lp: driver loaded but no devices found
[ 19.709051] parport_pc: VIA 686A/8231 detected
[ 19.709059] parport_pc: probing current configuration
[ 19.709079] parport_pc: Current parallel port base: 0x378
[ 19.709134] parport0: PC-style at 0x378, irq 7 [PCSPP,EPP]
[ 19.916717] lp0: using parport0 (interrupt-driven).
[ 19.916726] parport_pc: VIA parallel port: io=0x378, irq=7
[ 19.957628] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 20.332681] ppdev: user-space parallel port driver
[ 20.641391] type=1505 audit(1325359601.853:2): operation="profile_load" pid=494 name="/sbin/dhclient3"
[ 20.641885] type=1505 audit(1325359601.853:3): operation="profile_load" pid=494 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 20.642158] type=1505 audit(1325359601.853:4): operation="profile_load" pid=494 name="/usr/lib/connman/scripts/dhclient-script"
[ 21.381351] VIA 82xx Audio 0000:00:07.5: PCI INT C -> Link[LNKC] -> GSI 10 (level, low) -> IRQ 10
[ 21.381503] VIA 82xx Audio 0000:00:07.5: setting latency timer to 64
[ 23.400372] Adding 261112k swap on /host/ubuntu/disks/swap.disk. Priority:-1 extents:1 across:261112k
[ 24.110808] type=1505 audit(1325359605.321:5): operation="profile_load" pid=684 name="/usr/share/gdm/guest-session/Xsession"
[ 24.119729] type=1505 audit(1325359605.329:6): operation="profile_replace" pid=685 name="/sbin/dhclient3"
[ 24.146743] type=1505 audit(1325359605.357:7): operation="profile_replace" pid=685 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 24.147063] type=1505 audit(1325359605.357:8): operation="profile_replace" pid=685 name="/usr/lib/connman/scripts/dhclient-script"
[ 24.204148] eth0: link down
[ 24.216260] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 24.247641] type=1505 audit(1325359605.457:9): operation="profile_load" pid=686 name="/usr/bin/evince"
[ 24.288694] type=1505 audit(1325359605.501:10): operation="profile_load" pid=686 name="/usr/bin/evince-previewer"
[ 24.319640] type=1505 audit(1325359605.529:11): operation="profile_load" pid=686 name="/usr/bin/evince-thumbnailer"
[ 24.951914] vgaarb: device changed decodes: PCI:0000:00:0a.0,olddecodes=io+mem,decodes=none:owns=io+mem
[ 24.951924] vgaarb: transferring owner from PCI:0000:00:0a.0 to PCI:0000:01:00.0
[ 25.392772] [drm] nouveau 0000:00:0a.0: Allocating FIFO number 1
[ 25.393835] [drm] nouveau 0000:00:0a.0: nouveau_channel_alloc: initialised FIFO 1
[ 25.549095] [drm] nouveau 0000:00:0a.0: Setting dpms mode 0 on vga encoder (output 0)
[ 25.549108] [drm] nouveau 0000:00:0a.0: Output DVI-I-1 is running on CRTC 0 using output A
[ 32.596025]
[ 32.596036] floppy driver state
[ 32.596039]
[ 32.596046] now=4294900445 last interrupt=4294900098 diff=347 last called handler=e005a050
[ 32.596051] timeout_message=lock fdc
[ 32.596054] last output bytes:
[ 32.596057] 14 90 4294892702
[ 32.596060] 18 80 4294892702
[ 32.596063] 8 80 4294892703
[ 32.596065] 8 80 4294892703
[ 32.596068] 8 80 4294892703
[ 32.596071] 8 80 4294892703
[ 32.596073] 12 80 4294899705
[ 32.596076] 0 90 4294899705
[ 32.596079] 13 90 4294899705
[ 32.596082] 0 90 4294899705
[ 32.596084] 1a 90 4294899705
[ 32.596087] 0 90 4294899705
[ 32.596090] 3 80 4294899705
[ 32.596092] a1 90 4294899705
[ 32.596095] 10 90 4294899705
[ 32.596098] 7 80 4294899705
[ 32.596100] 0 90 4294899705
[ 32.596103] 8 81 4294900098
[ 32.596106] 7 80 4294900103
[ 32.596109] 0 90 4294900103
[ 32.596111] last result at 4294900098
[ 32.596113] last redo_fd_request at 4294892703
[ 32.596116] 70 0
[ 32.596129] status=81
[ 32.596131] fdc_busy=1
[ 32.596134] do_floppy=e005a050
[ 32.596136] cont=e005c8f0
[ 32.596139] current_req=(null)
[ 32.596142] command_status=-1
[ 32.596144]
[ 32.596149] floppy0: floppy timeout called
[ 32.799656] floppy0: unexpected interrupt
[ 32.799753] floppy0: sensei repl[0]=70 repl[1]=0
[ 135.289340] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
deaneve@ubuntu:~$
Last edit: 31 Dec 2011 19:31 by deanno.
31 Dec 2011 19:41 #16164 by PCW
the "[ 0.051457] Local APIC not detected. Using dummy APIC emulation."
Is not good. It probably means you cannot run 10.04 on your system
You can try wiki.linuxcnc.org/emcinfo.pl?TroubleShooting (section 2)
but I think that only applies to systems that have a LAPIC that is not enabed
31 Dec 2011 19:45 #16165 by deanno
Ok thankyou for your help. Would i try what is suggested in a terminal window
02 Jan 2012 02:41 #16196 by deanno
Tried editing as was suggested, still didn't work. I then tried the earlier version and everything is working. Perhaps the other one was a bad install on my part.
02 Jan 2012 12:27 #16206 by Rick G
If you mean you tried 8.04 and it worked while 10.04 did not that has been the case on several computers in the past.
If you do not have a need to go to 10.04 now just use the 8.04 and enjoy.
Rick H
Time to create page: 0.326 seconds
