× Forum Header
keep getting an error message, first time user
02 Jan 2012 22:59 #16226 by andypugh
deanno wrote:
Tried editing as was suggested, still didn't work. I then tried the earlier version and everything is working. Perhaps the other one was a bad install on my part.
If by that you mean Ubuntu 8.04, then that does confirm that the problem is the LAPIC. you probably won't be able to go any further up the Ubuntu versions than 8.04, but you should be OK with EMC2 up to version 2.6 at least, and you should have no trouble upgrading to 2.4.7 now and 2.5 when it is released.
03 Jan 2012 11:34 #16247 by Rick G
If going to 10.04 was really an issue, search the forum and you will find that others have been able to compile EMC and RTAI to work on some computers that have had similar problems. Not easy going.
Again it you do not need to don't worry about it for now.
Rick G
Time to create page: 0.050 seconds
