× Forum Header
Can't run new config
02 Mar 2012 03:44 - 02 Mar 2012 03:51 #18250 by beltramidave
Can't run new config was created by beltramidave
I have just run a new config using Step Wizard and I am getting an error so I can't open EMC2. I am trying to do a setup for a Probotix V90 and used the configuration from their website, but I must be missing something.
Debug: Could not open command file 'My'.[/b] My configuration is called "My V90". I could not copy and paste the whole message, so I hope this is enough.
I have been using one of the 'sim' configs without any issues before trying to make my own config
Thanks for any help.
Last edit: 02 Mar 2012 03:51 by beltramidave. Reason: could not attach screen shot of error
02 Mar 2012 04:25 #18251 by beltramidave
Replied by beltramidave on topic Re:Can't run new config
Here is the error message.
File Name: v90_config_error.txt
File Size:5 KB
02 Mar 2012 04:38 #18252 by PCW
Replied by PCW on topic Re:Can't run new config
Theres a whole thread that looks to be the same or related:
linuxcnc.org/index.php/english/component...d=9&id=17772&limit=6
(the first problem you have is you cant have a space in the file name without some magic so LinuxCNC only sees the "My")
02 Mar 2012 05:31 #18253 by beltramidave
Solved!!
It was my file name space giving me the problem. I should have known that you couldn't have spaces.
Thanks!!
02 Mar 2012 13:22 #18256 by BigJohnT
Replied by BigJohnT on topic Re:Can't run new config
In the 2.4.6 Stepconf Wizard My V90 is converted to My_V90, what version of EMC are you using?
02 Mar 2012 13:59 #18257 by beltramidave
Hi John,
I am running 2.4.3 May be a good time to upgrade!
02 Mar 2012 14:11 #18258 by BigJohnT
Yep, the latest version is 2.4.7 and it has all the bug fixes for 2.4 that are known.
Time to create page: 0.270 seconds
