× Forum Header
Need Help
21 Jun 2012 17:19 #21180 by ricky_a
Need Help was created by ricky_a
Hello
Now I've got my machine to run, but the settings are not right in stepconf wizard. It is a plasma cutter which version linuxcnc. should I use. Are there any who can help with my setup. I am beginner in cnc.
21 Jun 2012 19:30 #21181 by BigJohnT
Replied by BigJohnT on topic Re:Need Help
LinuxCNC 2.5 from the LiveCD will work with most machines.
We are all here to help... you just have to ask a question to speed up the process.
21 Jun 2012 20:03 #21184 by ricky_a
Replied by ricky_a on topic Re:Need Help
Thank you John
Which pulses / rev setting should I set my drivers.
Excuse my English I am from Denmark
21 Jun 2012 22:29 #21185 by BigJohnT
The pulses per rev depend on your gearing. If your from Denmark I assume your working in millimeters then one user unit is a mm. You need to determine how many pulses it takes to move the axis one mm. If you tell us what drivers and gear ratios you have we can help.
BTW, I enjoyed my visits to Denmark some years ago to Middelfart to visit the Enkotec factory.
24 Jun 2012 12:35 #21247 by ricky_a
Yes I work in millimeters.
Here's what I bought
PM542 Micro Stepping Driver
ZP5A-INT 5 axis breakout board
SPS407 Power supplies 42V
SY60STH88-3008BF High Torque three stack Nema 23, 1.8 degree hybrid stepper motor
I bought a machine from a flower company where there were many of the parts I needed.
My machine runs with Belts and pulleys on the X axis, Y axis and Z axis
Z axis also runs with spindle
X axis of the motor is a T5 25 tooth to a T5 48 teeth on the shaft.
shaft goes forward it to two T10 25 teeth that pull the sled
Y axis of the motor is a 25 tooth T10 to a T10 25 tooth
Z axis of the motor is a T5 15 tooth to a T5 25 teeth on the spindle. The spindle has an increase of 2 millimeters per revolution
Hope this is understandable.
In the cnc Linux, I can see there are several different programs depending on what kind of machine you have. Mine is indeed a plasma cutter, but the only program I can get to work, it is stepconf wizard creates.
24 Jun 2012 13:36 #21248 by BigJohnT
I googled the manual on your drive and it has many options for micro stepping. I'll use 2 microsteps for my example.
If you go to the X Axis Configuration page in the stepconf wizard you would enter
Motor Steps per revolution: 200
Driver Microstepping: 2
Pullet Teeth (Motor:Leadscrew) 25 : 48
Leadscrew Pitch ??? revolutions per mm
You gave the Z axis Leadscrew Pitch of 0.5 revolutions per mm so you need to figure out X and Y.
This should get you going...
24 Jun 2012 15:25 #21257 by ricky_a
I do not understand it completely, now I have measured.
X axis moves 130 mm per revolution
Y axis moves 250 mm per revolution
Z axis moves 2 mm per revolution
What about on the drivers that I can manually switch between 400-51200
In stepconf wizard basic machine information, should I change anything there.
24 Jun 2012 15:47 #21258 by ricky_a
24 Jun 2012 15:54 #21260 by ricky_a
24 Jun 2012 15:55 #21261 by ricky_a
Time to create page: 0.238 seconds
