Need Help
- ricky_a
- BigJohnT
- Thank you received: 1176
- ricky_a
y axis and z axis runs contrary to the equipment of what they do on the computer
how do I change it
- BigJohnT
- ricky_a
- Thank you received: 5013
thanks now it works, but I still have problems with distance. in stepconf wizard I got it to fit with distance, for example, 10mm. but when I run it in linuxcnc distances are only 5mm
Sounds like microstepping. Double the microstepping number in stepconf.
- ricky_a
I bought a laptop with parelle port, but it reports this error
- ricky_a
- ricky_a
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 Operation not permitted
Is this a LiveCD installation, or did you compile it?
You sometimes get this if realtime crashed previously. Might be worth restarting the PC and trying again.
