Forum Header
Setting up parallel port
- SteveT
16 Oct 2014 02:48 #52127
by SteveT
Setting up parallel port was created by SteveT
Hi
Can someone please give some help, I have installed a parallel port pci card to my PC as the mother board is without one, I have
identified its address which is e800 and e480 and have tried both in StepConf with no luck.
I have looked in the HAL ini file and probe_parport is present and I am still not connecting to the driver!!!
Now I am at a bit of a loss on what to check next
Steve
Steve
- ArcEye
- Thank you received: 758
16 Oct 2014 13:14 - 16 Oct 2014 17:20 #52134
by ArcEye
Replied by ArcEye on topic Setting up parallel port
Hi
In a terminal, run lspci -vv > lspci.txt and post the resulting file lspci.txt
You probably have 4 addresses listed, 2 are ports and 2 are data registers, you have likely chosen the wrong addresses.
Which is which is often counter intuitive.
see also my FAQ at
www.linuxcnc.org/index.php/english/forum...-parallel-port-cards
see also my FAQ at
Last edit: 16 Oct 2014 17:20 by ArcEye.
The following user(s) said Thank You: SteveT
- SteveT
19 Oct 2014 22:30 #52192
by SteveT
Replied by SteveT on topic Setting up parallel port
- ArcEye
19 Oct 2014 22:40 #52193
by ArcEye
01:05.2 Parallel controller: NetMos Technology PCI 9865 Multi-I/O Controller (prog-if 03 [IEEE1284])
Subsystem: Device a000:2000
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 64, Cache Line Size: 64 bytes
Interrupt: pin C routed to IRQ 17
Region 0: I/O ports at e800
Region 1: I/O ports at e480
Region 2: Memory at fdffb000 (32-bit, non-prefetchable) [size=4K]
Region 4: Memory at fdffa000 (32-bit, non-prefetchable) [size=4K]
Capabilities: <access denied>
Kernel driver in use: parport_pc
There are 2 issues here
1) there is only one parport, it is probably at 0xe480, the port is normally the lower address on Netmos boards, the other address is the register
2) The port has been claimed by parport_pc, which will prevent hal claiming it at boot of Linuxcnc
Try opening a terminal and issuing
sudo rmmod parport_pc
sudo rmmod ppdev
sudo rmmod lp
modprobe parport
Then run stepconf again and see if it recognises the port
If it does the unwanted modules can be blacklisted (they should be already)
sudo rmmod ppdev
sudo rmmod lp
modprobe parport
- SteveT
19 Oct 2014 23:07 #52194
by SteveT
Hi
I get this error
steven@CNC:~$ sudo rmmod parport_pc
[sudo] password for steven:
Error: Module parport_pc is in use
steven@CNC:~$
Steve
I get this error
steven@CNC:~$
Steve
- ArcEye
19 Oct 2014 23:22 #52195
by ArcEye
Try unloading ppdev first, this was off the top of my head, I'm not at a linux box right now.
- ArcEye
20 Oct 2014 00:30 - 20 Oct 2014 16:19 #52197
by ArcEye
Alternately, try creating a file called /etc/modprobe.d/linuxcnc.conf
which contains
blacklist ppdev
blacklist parport_pc
then reboot and run
lsmod
and check that parport is loaded and that ppdev and parport_pc are not
You need parport loaded for low level access to the parallel port, but not ppdev and parport_pc, which will claim the port and prevent linuxcnc from doing so
If parport is not loaded then
modprobe parport
To make this permanent, add the line
parport
to /etc/modules
which contains
blacklist ppdev
then reboot and run
lsmod
modprobe parport
parport
to /etc/modules
Last edit: 20 Oct 2014 16:19 by ArcEye.
- SteveT
20 Oct 2014 23:17 #52214
by SteveT
Hi
I think that has worked, this is the output from "lsmod" as far as I can tell hal has conected to the paraport.
Thanks for your help it is very much appreciated. Steve
steven@CNC:~$ lsmod
Module Size Used by
charge_pump 12383 0
stepgen 16544 0
hal_parport 16727 0
probe_parport 12446 0
motmod 153177 0
trivkins 12495 1 motmod
hal_lib 39487 6 probe_parport,trivkins,hal_parport,stepgen,charge_pump,motmod
rtapi 34887 6 probe_parport,hal_parport,stepgen,charge_pump,hal_lib,motmod
rtai_math 56034 0
rtai_sched 191741 1 rtapi
rtai_hal 231371 2 rtapi,rtai_sched
bnep 17186 2
rfcomm 36117 0
bluetooth 166348 10 bnep,rfcomm
rfkill 18403 2 bluetooth
lp 12767 0
parport 35208 2 lp,hal_parport
uinput 17057 1
nfsd 202675 2
nfs 277039 0
nfs_acl 12464 2 nfs,nfsd
auth_rpcgss 32226 2 nfs,nfsd
fscache 35490 1 nfs
lockd 56898 2 nfs,nfsd
sunrpc 151263 6 nfs,nfsd,auth_rpcgss,lockd,nfs_acl
loop 21832 0
nouveau 722446 3
mxm_wmi 12468 1 nouveau
wmi 17148 2 mxm_wmi,nouveau
video 17461 1 nouveau
ttm 54921 1 nouveau
drm_kms_helper 26601 1 nouveau
drm 169993 5 ttm,drm_kms_helper,nouveau
thermal_sys 17699 1 video
power_supply 13320 1 nouveau
i2c_algo_bit 12648 1 nouveau
i2c_nforce2 12521 0
k10temp 12540 0
i2c_core 23097 5 drm,drm_kms_helper,i2c_algo_bit,nouveau,i2c_nforce2
evdev 17099 9
button 12818 1 nouveau
ext4 270189 1
crc16 12328 2 ext4,bluetooth
jbd2 54294 1 ext4
mbcache 12899 1 ext4
sg 25482 0
sr_mod 21529 0
cdrom 38893 1 sr_mod
sd_mod 43403 3
crc_t10dif 12333 1 sd_mod
usbhid 39608 0
hid 72252 1 usbhid
usb_storage 39140 0
floppy 51935 0
ata_generic 12440 0
microcode 17386 0
forcedeth 56263 0
ohci_hcd 26266 0
pata_amd 13084 0
sata_nv 22085 2
libata 152992 3 sata_nv,pata_amd,ata_generic
scsi_mod 125436 5 sg,usb_storage,libata,sd_mod,sr_mod
ehci_hcd 43561 0
usbcore 124257 5 usb_storage,ohci_hcd,ehci_hcd,usbhid
usb_common 12339 1 usbcore
steven@CNC:~$ lsmod
Module Size Used by
charge_pump 12383 0
stepgen 16544 0
hal_parport 16727 0
motmod 153177 0
rtai_math 56034 0
bnep 17186 2
rfcomm 36117 0
lp 12767 0
uinput 17057 1
nfsd 202675 2
nfs 277039 0
fscache 35490 1 nfs
loop 21832 0
nouveau 722446 3
ttm 54921 1 nouveau
i2c_nforce2 12521 0
k10temp 12540 0
evdev 17099 9
ext4 270189 1
jbd2 54294 1 ext4
sg 25482 0
sr_mod 21529 0
sd_mod 43403 3
usbhid 39608 0
hid 72252 1 usbhid
usb_storage 39140 0
floppy 51935 0
ata_generic 12440 0
microcode 17386 0
forcedeth 56263 0
ohci_hcd 26266 0
pata_amd 13084 0
sata_nv 22085 2
ehci_hcd 43561 0
- ArcEye
20 Oct 2014 23:22 #52216
by ArcEye
Yep, that all looks about right.
On to the next challenge (problem)
- dennis.lewis5
- Thank you received: 5
01 Jul 2015 23:11 #60312
by dennis.lewis5
Replied by dennis.lewis5 on topic Setting up parallel port
I have added a pci card with two parallel ports on it. I can use ptest to activate/read one port which is all I need. However when in stepconfig I specify a second port but do not get a panel to define any connections on the second port.
using the guidance in this topic it looks as if there is no contention for the port. any suggestions?
Time to create page: 0.090 seconds
