× Forum Header
Forward Step / Backward Step - Vexta Question
12 May 2018 15:31 - 12 May 2018 15:32 #110606 by Grotius
Replied by Grotius on topic Forward Step / Backward Step - Vexta Question
@Hi Brenda,
For your motor scaling, you can use following example, if your drive is up to 10000 you know what to change :
## Calculation ##
# drive : 5000 steps / rev
# pitch : 4 mm / rev
# calcutation : 5000 / 4 =
# scale = 1250
[AXIS_2] # Z-axis
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 25
MAX_ACCELERATION = 100
STEPGEN_MAXACCEL = 150
SCALE = 1250
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -1000
MAX_LIMIT = 1000
HOME_LATCH_VEL = 5
HOME_SEARCH_VEL = 10
HOME_FINAL_VEL = 5
HOME_OFFSET = 0
HOME_SEQUENCE = 1
The stepconfig wizzard is very confusing to me. So this formula makes it very simple to handle.
Last edit: 12 May 2018 15:32 by Grotius.
12 May 2018 17:07 - 12 May 2018 17:16 #110611 by BrendaEM
Replied by BrendaEM on topic Forward Step / Backward Step - Vexta Question
Thank you.
I used a Arduino utility I wrote RDL to test my calculations each axis as I was building the machine. It gets tiresome turning ballscrews by hand.
forum.arduino.cc/index.php?PHPSESSID=0qo...ic=469343.msg3213804
I post this thing here and there, because I thought that people could sort out a lot before they come here and ask a lot of noob questions like I have.
Without microstepping 2 of my machine's axis resolution is limited to .02mm, with microstepping on it would be .01mm. Accuracy may vary. 10mm screw, .72deg motors (500 steps).
Last edit: 12 May 2018 17:16 by BrendaEM.
12 May 2018 17:19 - 12 May 2018 17:21 #110612 by BrendaEM
BTW, is the HAL I am using for Forward Step / Backward Step (Vexta) So Far.
Todo: Limit switch issues. They are being read, and home, almost. Could be bouncing, could have been the options I chose whilst running Stepconf.
File Name: BrendaCNC_...5-12.hal
File Size:6 KB
Last edit: 12 May 2018 17:21 by BrendaEM.
12 May 2018 18:10 - 12 May 2018 18:22 #110614 by BrendaEM
I shot a small jogging video.
www.facebook.com/brenda.make/videos/1710303622380662/
I will put more some videos on Youtube, but like many people youtube ripped me off for adsense, so I'm not too happy with them right now.
For now, I am only using 100 for acceleration because the cart needs to be immobilized. I think the motors will go faster, but this is fast enough to learn how to crash a CNC machine, and send milling bit shrapnel across the garage.
Oddly, the machine looks bigger in person. The frame 4 feet wide and 5 feet long. The work envelope will be 910mm x 1100 x 120mm ( 35" wide x 43" long x 4.5" high ) The weight is about dontwannadroponme, or perhaps just under 250 lbs.
Thanks everyone : )
Last edit: 12 May 2018 18:22 by BrendaEM.
Time to create page: 0.199 seconds
