Forum Header
Configuring A rotary axis to substitute for the Y axis
- Chris401
7 years 8 months ago #125491
by Chris401
Replied by Chris401 on topic Configuring A rotary axis to substitute for the Y axis
Leon,
I figured out how to get Vcarvepro to output angular movements and and am running an XYZA with a nonexistent Y axis. It now works but the A axis seems to be turning at the same magnitude in degrees/min that the linear axis moves in inches/min. Obviously the rotation is pretty darned slow. Moving the right amount just getting there slowly. Is that just something that needs overcome in the G code or is there a linuxcnc end fix?
- Chris401
7 years 8 months ago #125493
by Chris401
Andy,
I have Vcarve ouputing A moves now and the machine is moving the right amounts. But the feed for the A axis is the same in deg/min as the linear is in inches/min. Obviously kind of slow. Is there a linuxcnc fix for rotational moves or does that just have to be a G code fix?
- Grotius
- Thank you received: 2349
7 years 8 months ago #125494
by Grotius
Replied by Grotius on topic Configuring A rotary axis to substitute for the Y axis
In rotary files, the feed rates are up to 30000 mm/min when rotating without G1 commands.
So you need to add fast command's in your gcode file, like
Y5 Z68 A-220 F35000
Y5 Z68 A-220 F35000
- OttoDidact
- Thank you received: 3
7 years 8 months ago #125495
by OttoDidact
Replied by OttoDidact on topic Configuring A rotary axis to substitute for the Y axis
I think what you are looking for is inverse time mode.
- Leon82
- Thank you received: 79
7 years 8 months ago - 7 years 8 months ago #125499
by Leon82
Yes. Inverse time or TCP would feed correctly
In mastercam you can set the machine definition to post this. So there should be a setting in the cam software
Replied by Leon82 on topic Configuring A rotary axis to substitute for the Y axis
OttoDidact wrote: I think what you are looking for is inverse time mode.
Last edit: 7 years 8 months ago by Leon82.
- Leon82
7 years 8 months ago #125501
by Leon82
Time to create page: 0.754 seconds
