- Configuring LinuxCNC
- Configuration Tools
- StepConf Wizard
- Help: configure a Servo motor with (PUL/DIR) as a Spindle by Par-port stepconfig
Forum Header
- Thank you received: 5336
21 Nov 2024 08:32 #314981
Replied by PCW on topic Help: configure a Servo motor with (PUL/DIR) as a Spindle by Par-port stepconfig
A couple of things:
You should use reset mode for all axis/spindle
this should double you maximum step rate
Can you post your current hal/ini files?
The following user(s) said Thank You: sk_linuxcnc
- sk_linuxcnc
22 Nov 2024 02:48 #315020
by sk_linuxcnc
Replied by sk_linuxcnc on topic Help: configure a Servo motor with (PUL/DIR) as a Spindle by Par-port stepconfig
**the values in the Z axis config are just a replica of the parameters i used for A axis in a different config. (in reality i dont have a Z axis.)
the attached post is where i describe my machine, and the use case of Spindle, instead of A axis. but i would be really happy if you could give your 2 cents on this matter too!
forum.linuxcnc.org/20-g-code/54516-help-...usly?start=10#314987
- sk_linuxcnc
22 Nov 2024 06:28 #315029
by sk_linuxcnc
i do not understand what is a reset mode. and where to call it/place it and in which file.
22 Nov 2024 11:57 - 22 Nov 2024 12:12 #315040
Your X axis is using reset mode but the spindle is not:
net xstep => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1 <<<<<<<<<<<<<<<
net xdir => parport.0.pin-03-out
net spindle-step => parport.0.pin-04-out
setp stepgen.0.steplen 1 <<<<<<<<
setp stepgen.0.stepspace 0 <<<<<<<<<
Also the spindle scale should be 800 for 800 steps/turn since you
are setting the stepgen velocity in RPS
(it should be 13.33333 if you set the stepgen velocity in RPM)
Last edit: 22 Nov 2024 12:12 by PCW.
- sk_linuxcnc
26 Nov 2024 08:59 #315303
by sk_linuxcnc
thank you. i did everything like you mentioned and it works. setting steplen to 1 and stepsace to 0 along with pin reset 1 increases the total rpm i can acheive with my motor. ( now it rotates much faster than it did with scale at 6400)
what doesnt work (or is counter intuitive) is when i set the spindle scale to 800 (as my servo is set to 800 pulses/rev) the spindle turns very slowly.
when i put it to 6400, it turns much faster.
and when i put it to 64000 it turns even faster.
but as it works for me, ill leave it at that. thanks again!
- StepConf Wizard
Time to create page: 0.707 seconds
