- Configuring LinuxCNC
- Configuration Tools
- StepConf Wizard
- Trying to move from UCCNC to Linuxcnc and using 7i96s but having trouble
Forum Header
- Mark Kraus
19 Jan 2026 19:01 #341584
by Mark Kraus
Replied by Mark Kraus on topic Trying to move from UCCNC to Linuxcnc and using 7i96s but having trouble
I have been trying to get the encoder working for the past 1.5 days. It is an amt102-v 5 wire a b index. It worked well in uccnc but all i get when m3 is at speed light comes on.
- Thank you received: 5334
19 Jan 2026 19:41 #341586
Replied by PCW on topic Trying to move from UCCNC to Linuxcnc and using 7i96s but having trouble
Can you post your current hal/ini files?
There are basic steps to verify encoder operation
1. Run halshow
2. Select the watch tab and then the 7I96S encoder position pin and verify that it
increments by 1 for each forward turn of the spindle
If not you need to check the scaling, encoder connections etc
1. Run halshow
- Mark Kraus
23 Jan 2026 13:49 #341758
by Mark Kraus
I was not getting anything on halshow and then I used a multimeter on the encoder and did not get anything. I thought it may have been damaged so I ordered another and hope to install it Sat or Monday.
- Thank you received: 4152
23 Jan 2026 20:03 #341790
Replied by rodw on topic Trying to move from UCCNC to Linuxcnc and using 7i96s but having trouble
Please share your hal and ini file. There are some settings required to enable the Mesa encoder inputs
- Mark Kraus
26 Jan 2026 13:28 #341940
by Mark Kraus
The encoder came in and would like to ask what is the best ppr setting to select? I will have max 3600 rpm and i want to do rigid tapping.
rotational speed (at each
resolution)
192, 384, 400, 500, 800, 1000, 1024, 2048 7500 RPM
48, 96, 100, 125, 200, 250, 256, 512 15000 RPM
resolution)
- Mark Kraus
26 Jan 2026 22:08 #341973
by Mark Kraus
I opened another thread and have them posted there.
- StepConf Wizard
