Forum Header
Setting up a Zenbot
- steeley
23 Mar 2011 21:06 #8033
by steeley
Setting up a Zenbot was created by steeley
Anyone using a Zenbot? I'm looking for a basic config. to get started.
I haven't manged to find anything on the web as yet, and the manufacturer
hasn't give me any answer to my enquiries.
I'm tempted to fiddle, but I don't want to break anything
TIA
TIA
- Thank you received: 4994
23 Mar 2011 22:27 #8036
Replied by andypugh on topic Re:Setting up a Zenbot
Just fire up stepconf and guess
Configure the limit switches first.
- steeley
23 Mar 2011 22:48 #8037
by steeley
Replied by steeley on topic Re:Setting up a Zenbot
thanks-
no limit switches so need to be careful...
Given it a go with stepconf and everything runs in the right direction- I've gone for slow speeds
to start with. Motion seems fine and smooth.
steppers are 200 steps/rev with 8th microstepping. There is some scaling wrong somewhere
as moving 0.1 inch on any axis moves about 3inches, but I cant see where.
- Rick G
- Thank you received: 155
24 Mar 2011 10:01 #8043
by Rick G
Replied by Rick G on topic Re:Setting up a Zenbot
Make sure you have all your settings, hardware and software correct first.
Then
You can just go back to Stepconf and enter the proper numbers to reach the movement you want.
or
Measure the movement you get from a move with the scale you have, calculate what scale would give proper results and
edit the SCALE in you config file to reach the correct movement.
There is a great deal of info on SCALE in the Integrator Manual
www.linuxcnc.org/docs/EMC2_Integrator_Manual.pdf
Rick G
Then
or
Rick G
- steeley
24 Mar 2011 21:52 #8058
by steeley
Thanks folks- had a fiddle and just needed to set the leadscrew to match the turns per inch of the stepper.
One thing I can't find is how to send the machine back to the zero position?
- Rick G
25 Mar 2011 10:29 #8062
by Rick G
If you homed your machine at x0 y0 z0.
And then you did a touch off at some other location.
If you enter G53 G0 X0Y0Z0
It will take you back to the homed position.
A good source to read...
www.linuxcnc.org/docs/html/gcode.html
Rick G
Rick G
- steeley
28 Mar 2011 12:19 #8195
by steeley
Thanks- was just trying to do a bit less typing
28 Mar 2011 12:37 #8199
You can set up an MDI_COMMAND to go to home on a physical or software button.
linuxcnc.org/docs/html/gui_halui.html#sub:MDI
- steeley
29 Mar 2011 09:30 - 29 Mar 2011 09:31 #8247
by steeley
thanks- just been digging into that doc- interesting
Last edit: 29 Mar 2011 09:31 by steeley.
29 Mar 2011 10:23 #8250
I have a bunch of PyVCP buttons which call various fixed subroutines on my CNC lathe.
It's a very useful feature.
Time to create page: 0.160 seconds
