× Forum Header
Setting up a Zenbot
30 Mar 2011 12:54 #8283 by steeley
Replied by steeley on topic Re:Setting up a Zenbot
Thanks Andy- Are these available for download somewhere?
30 Mar 2011 14:12 #8286 by andypugh
Replied by andypugh on topic Re:Setting up a Zenbot
Yes, www.bodgesoc.org/lathe/lathe.html
However, as I have been saying in another thread, there are rather neater and better ways to achieve that functionality in newer versions of EMC2 (GladeVCP, NGCGUI)
10 Apr 2011 16:33 #8744 by steeley
I now seem to have what is a basically functional machine, but my motors seems to whine/buzz even when
the software is doing nothing.
Tried a different LPT cable, but it didn't make much difference.
I've found that:
Removing LPT cable stops the noise.
If motors are disabled, it seems to stop the noise.
Any clues on this one?
TIA
10 Apr 2011 16:52 #8745 by cncbasher
Replied by cncbasher on topic Re:Setting up a Zenbot
remember steppers are energised when stationary , so are drawing current , could be your tuning is slightly off , or the stepper drives are running at too high a rate of microstepping that the motors and your pc are happy with
10 Apr 2011 17:27 #8746 by andypugh
Mine do too.
The motor are still drawing full current when stationary, but possibly at quite a low PWM duty cycle. I think that is probably enough to create noise.
In other words, don't worry about it.
10 Apr 2011 17:47 #8747 by steeley
thanks-
Ok maybe I can keep the motors disabled when not running a job- assuming that will stop it.
Is it possible to set a 'motor enable' LPT pin for each axis?
10 Apr 2011 18:57 #8749 by andypugh
I turn mine off (second from left button). I have all the amp-enables for the drivers wired to one output pin.
10 Apr 2011 21:11 #8750 by steeley
wiring to one pin sounds a good idea for now.
However, having used steppers in other projects which didn't have this issue
I'd like to get rid of the noise if poss.
19 May 2011 18:04 #9933 by steeley
Almost there...
except everything comes out half-size :(
If I manually jog the machine it moves correctly (i.e x1 y1 moves x 1", y1") but the Axis display shows it
moving twice as far.
All my .conf numbers seem to be correct-I guess if they were wrong x1 etc wouldn't move 1 inch.
TIA
19 May 2011 18:46 #9934 by BigJohnT
Replied by BigJohnT on topic Re:Setting up a Zenbot
How far does it move from X0 when you put G0 X1 in the MDI window?
Time to create page: 0.078 seconds
