GIGABYTE GA-D525TUD Intel Atom D525
- Rick G
- Thank you received: 155
11 Sep 2012 11:22 #24157
by Rick G
Replied by Rick G on topic Re:GIGABYTE GA-D525TUD Intel Atom D525
As a side note the Dell always had a spike when starting with 8.04.
The Dell also would not run with 10.04, ridiculous latency numbers.
After building from scratch as shown on previous threads to allow the computer to run with 10.04 the initial spikes disappeared.
Rick G
Rick G
- jmelson
- Thank you received: 158
12 Sep 2012 03:42 #24177
by jmelson
Replied by jmelson on topic Re:GIGABYTE GA-D525TUD Intel Atom D525
dab77 wrote:
it MAY occur again without a message. But, in my experience, it also seems to
often not recur as a delay in the thread.
Jon
Warning! That latency error is only REPORTED once per startup of the RT thread.I've always wanted to know.. can one live with the initial realtime error, if then it doesn't appear anymore during use?
Jon
- Rick G
12 Sep 2012 07:52 #24183
by Rick G
In my case I was referring to running the latency test.
Rick G
Good point.Warning! That latency error is only REPORTED once per startup of the RT thread.
Rick G
- Thank you received: 4967
12 Sep 2012 14:54 #24195
Replied by andypugh on topic Re:GIGABYTE GA-D525TUD Intel Atom D525
jmelson wrote:
There is a HAL parameter,( motion.servo.overruns ) that counts over-runs. If you see the RT delay fault, then it is worth monitoring that pin with a Halmeter.
If it's only 1 or 2, then perhaps live with it. If it is rising continually then there is a real problem.
- danemc
14 Jan 2013 09:50 #28672
by danemc
Replied by danemc on topic GIGABYTE GA-D525TUD Intel Atom D525
i'm glad i found this thread as i was considering an amd e-350d powered board i came across but after seeing so many posts about atom cpu's i didin't know if the apu was viable. also thinking about an atom board with a d2500 (no hyperthreading but plenty of clock speed.) but may go with something more proven in the forum. is it your opinion that the asus board would be a better candidate to run stepper motors? i'm still trying to put together the pieces on what parameters effect what.
Time to create page: 0.056 seconds
