- Thank you received: 13
Reducing latency on multicore pc's - Success!
- RGH
13 years 10 months ago - 13 years 10 months ago #27492
by RGH
Reducing latency on multicore pc's - Success! was created by RGH
think I should introduce myself a little as this is my first post:
I'm a "new" emc2 user. Actually I'm even kind of new to linux too although I played around with Debian and consumed some books some years ago setting up some home server stuff. Whatever, to keep the story short: Went from mach3 to emc2 because of the possibilities and offered freedom to do things that I possibly can't even yet imagine to do (I already love it!). I'm not a OS tinker guy if there is no need (prefer to play with things that fly, drive, move or make chippings instead of operating systems) but as the ultimate goal is making chippings I decided to take the trouble...
And now on the topic:
My emc2 pc is a core2duo, 2.4GHz. For Vga I have a bunch of ATI and Nvidia cards that all work ok and don't influence the latency.
I went somehow crazy about the latency value and played around till I reached <4000ns of jitter under any circumstance I could think of (e.g. 2xfull-hd video playing simultaneously, copying 100gb of data over the network, dd'ing two usb-sticks and two hdds, running 5x glxgears).
My initial max jitter value was 30000ns. With the goal of dedication one core to the rt-engine I researched and found the isolcpus-magic. This Improved things quite a bit but I was still above 10000ns. A little bit more research on the topic of dedicating cpu's helped reducing the latency to the current value of less than 4000ns. What I do is manipulating the IRQ affinity. As I have not found anything about this topic related to linuxcnc I thought that it might make sense to share the resulting scripts and confs and stuff...
First of all my bios settings:
CPU
- disable Vanderpool Technology (cpu vitualization stuff for vm's)
- disable C1E support
- enable TM support (temperature monitoring - will throttle cpu if it overheats e.g. because of fan malfunction - will mess things up but better than a crash and toasted chip)
GENERAL
- disable anything that suggests that it could save power or automatically improve performance (over-clocking)
- enable APIC (advanced programmable interrupt controller), on my machine linux refused to see two separate cores if it was not enabled and furthermore we need it to redirect the IRQs anyway
- disable anything suggested by the makers of linuxcnc (although on my machine nothing else made a difference)
Linux related changes:
- edit /etc/default/grub and add the kernel options "isolcpus=1 acpi_irq_nobalance noirqbalance" (call update-grub afterwards)
- make sure that the software "irqbalance" is NOT installed, remove if it is there (Ubuntu software center -> installed software -> search for irqbalance -> remove)
- add the upstart script "irq-affinity.conf" to /etc/init (see attachments, it will move the irq-handling to the first core)
- add the sh scripts set-irq-affinity and watchirqs to /usr/local/sbin (first allows to set the affinity mask manually, second opens a console window that shows live how the irqs are scheduled to the different cores -> all numeric irqs but 0 should be handled by cpu0)
Well, that's it - hope it helps somebody!
Cheers,
Ruben
PS:
Could somebody explain the lut5 function in detail? I used it to configure my combined homing/limit switches for xy by modifying the generated hal file and the signal routing is clear but I really don't understand the function itself even after reading 10+times the description of the function. What I understand is that it is 5 inputs, one output and a 32bit - mask that allows setting the desired in->out behaviour. I would be grateful for some further explanations on that mask. (I'm a software guy so feel free to keep it technical)
CPU
GENERAL
Cheers,
Ruben
PS:
Last edit: 13 years 10 months ago by RGH. Reason: added attachment
The following user(s) said Thank You: tensor, kivig, Doc Alex, steinbeisser
- Thank you received: 5334
13 years 10 months ago #27493
Replied by PCW on topic Reducing latency on multicore pc's - Success!
The LUT 5 function probably confused you because its is too simple
The output bit is selected from the mask by the 5 input bits, that is the 5 input bits comprise an address to the bits in the mask and the output is simply the mask value at that bit address. That is a input value 0f 00000b returns the mask bit 0, an input of 00001b returns the mask bit 1 etc etc.
- ArcEye
- Thank you received: 240
13 years 10 months ago #27498
by ArcEye
Replied by ArcEye on topic Reducing latency on multicore pc's - Success!
Hi
Sounds interesting, look forward to examining the scripts etc.
It will only accept certain extensions and sizes. Easiest is normally to roll everything up into a .zip, will accept up to 500K in this format.
You don't say so, but I assume you are using the Ubuntu 10.04 based install?
[How are attachments added? Thought it would be as intuitive as it seems but it does not work.]
- BigJohnT
- Thank you received: 994
13 years 10 months ago #27518
by BigJohnT
Confuses me too... so you can have either an and or an xor function and the xor is obtained by summing the weights of bits. So for an example if I set the weight to 0x18 then if bit 2 is the only one on (0x10) the output is on, and if bit 0 and bi1 is the only thing on (0x8) then the output is on. This gives me a combination xor plus an and function. Getting clearer now. Dang that man page need some fixing up.
Replied by BigJohnT on topic Reducing latency on multicore pc's - Success!
PCW wrote: The LUT 5 function probably confused you because its is too simple
13 years 10 months ago - 13 years 10 months ago #27520
This is hexadecimal so a weight of 0x10 represents bit 4 and 0x18 is bit 3 and bit 4
so 0x18 would generate a function that was true only when the inputs
= 3 or 4. that is inputs = 00011b 0r 00100b (little b means binary)
The 'weight's are a little confusing as they are just a way to easily
specify the 32 by one bit look up table data as a single 32 bit data word
so a weigh of 1 sets bit 0 in the table
a weight of 2 sets bit 1
a weight of 4 sets bit 2
a weight 0f 0x80000000 sets bit 31 (the last bit)
If you think of the inputs as an address to the bits (0 through 31) in the function
it should be clearer. So basically you have a look up table that instead of using an
array for the table data, uses a 32 bit data word where the inputs are an index into the
individual bits of the data word.
BTW I would really like to try the latency tweaks and thanks to arceye for explaining the
attachment issues. I tried and failed with attachments before and it good to know the zip trick
Last edit: 13 years 10 months ago by PCW.
- BigJohnT
13 years 10 months ago - 13 years 10 months ago #27523
by BigJohnT
I'm sure I don't understand what your saying...
Looking at the truth table in the man page
0x8 is bit 0 and bit 1
0x10 is xor bit 2
Testing this in hal and it does work as an and with bit 0 and 1 and as an xor with bit 2, any other combinations and the output is false.
0x10 is xor bit 2
Last edit: 13 years 10 months ago by BigJohnT.
Time to create page: 0.845 seconds
