m8298 wrote: I downloaded and installed hidcomp. I have it recognizing my Contour Shuttle Pro. Can anyone explain to me how to set pins in hal so I can link them in hidcomp? I want the following functions assigned to hal pins to be used on the buttons:
One pin/button for each axis (xyza) to jog enable.
One pin/button to set a parallel port output.
One pin/button for program run.
One pin/button for program stop.
One pin/button for program rewind.
One pin/button for estop.
One pin/button to zero A axis.
One pin/button to switch in/mm.
One pin/button to set a position offset. (I still need to learn how to do this in EMC. It is to set X and Y position based on a laser pointer.)
m8298 wrote: Am I wrong here?
m8298 wrote: Can you tell me where I find the pins it creates?
