You may also select "watch" and confirm that pushing a button or moving a dial has the desired effect on a pin and which pin it is.If, (and only if) LinuxCNC is currently starting without an error, you can see them all in the Machine->Show Hal Config screen of Axis (Other GUIs will vary).
