Raspberry Pi 4
- Bertho
- Thank you received: 4
23 Sep 2019 21:19 #146005
by Bertho
Then you should also be able to see the log message of the driver stating which RPi you are running it on (if the message/debug level is at INFO).
Replied by Bertho on topic Raspberry Pi 4
Nice.Works for me (at least on RPI3,7C81)
- Thank you received: 5330
23 Sep 2019 22:18 #146011
Replied by PCW on topic Raspberry Pi 4
I dont get that message
is it the hostmot2 debug settings I need to change?
- Bertho
24 Sep 2019 04:47 #146034
by Bertho
You can set the "spi_debug" parameter on the hm2_rpspi driver in the configuration to 3 (INFO level) or, if you are adventurous, 4 (DEBUG level). That should get you a noisy log file. Setting it to 5 will enable any and all messages generated by any hal component. Note that this parameter will affect the entire hal message setting, so all modules will start spewing extra information.I dont get that message
- cakeslob
- Thank you received: 280
25 Sep 2019 02:44 - 25 Sep 2019 02:45 #146126
by cakeslob
Replied by cakeslob on topic Raspberry Pi 4
This is working with the 7c81 and rpi4, thanks
Last edit: 25 Sep 2019 02:45 by cakeslob.
- Bertho
25 Sep 2019 05:03 #146129
by Bertho
There is probably nothing preventing a pull request now to get this change in the main repo. I guess this should be added to both 2.7, 2.8 and 2.9 branches.
Success! Thanks for the feedback.This is working with the 7c81 and rpi4, thanks
- acondit
25 Sep 2019 15:11 #146169
by acondit
Replied by acondit on topic Raspberry Pi 4
I got linux-5.2.14-rt7 running on my RockPro64. So, I used John Thornton's instruction for the raspberry pi4b and built linuxcnc (userspace) .
I was able to start linuxcnc via ssh from my mac and got the config selector window. I didn't have my 7i76e plugged in because I haven't bought a USB3 to ethernet converter. Now that I have rt_preempt and linuxcnc both apparently running I will have to do that.
Thank you John.
Thank you John.
- Chris D
29 Sep 2019 13:37 #146558
by Chris D
Replied by Chris D on topic Raspberry Pi 4
" the 7C80 still needs its inmux firmware module support added to the hostmot2 driver"
What does that mean?
Chris D
Chris D
29 Sep 2019 15:24 #146591
It sounds like the 7C80 uses a Hostmot2 module that is not currently supported by the LinuxCNC driver.
Hostmot2 defines a number of modules, with an identifying code:
github.com/LinuxCNC/linuxcnc/blob/master...tmot2/hostmot2.h#L92
(I suspect that some marked as "not supported" are actually now supported. But "inmux" is not even listed.)
Each GTAG type has its own driver file, for example GTAG 128, led, is handled by led.c
github.com/LinuxCNC/linuxcnc/blob/master.../mesa-hostmot2/led.c
(I chose that one as it is the simplest of them, but all the driver files follow the same structure)
The very first thing I did with LinuxCNC coding was write the tp_pwmgen driver to enable use of the 7i49 card. If you fancy a project....
Replied by andypugh on topic Raspberry Pi 4
- acondit
29 Sep 2019 15:45 #146592
by acondit
I tried again to build linuxcnc-uspace on my rockpro64 but I am getting some errors on
"sudo dpkg -i linuxcnc-uspace_2.8.0~pre1_arm64.deb"
(Reading database ... 185225 files and directories currently installed.)
Preparing to unpack linuxcnc-uspace_2.8.0~pre1_arm64.deb ...
Unpacking linuxcnc-uspace (1:2.8.0~pre1) over (1:2.8.0~pre1) ...
dpkg: dependency problems prevent configuration of linuxcnc-uspace:
linuxcnc-uspace depends on python-gtksourceview2; however:
Package python-gtksourceview2 is not installed.
linuxcnc-uspace depends on python-vte; however:
Package python-vte is not installed.
linuxcnc-uspace depends on gstreamer1.0-plugins-base; however:
Package gstreamer1.0-plugins-base is not installed.
linuxcnc-uspace depends on python-xlib; however:
Package python-xlib is not installed.
The instructions say:
Now edit debian/control.bottom.in and remove the following lines
python-vte,,
but the lines are not in debian/configure so I can't delete them.
So does anybody have any suggestions??? They are obviously being referenced from somewhere.
python-vte,,
- Chris D
29 Sep 2019 15:52 #146593
by Chris D
Thanks for the information Andy. If I only had time for all the projects I have active now:(
Chris
Chris
